Questionable Noise from 5.0 SC (Anyone know what it is?)
Old Nov 26, 2020 | 03:29 PM
Gr8DaneFilms's Avatar
Default Questionable Noise from 5.0 SC (Anyone know what it is?)
Hey everybody, I’m new to the forum but I’ve had my 2011 XKR for about a year and a half now and it’s been an amazing experience!
That being said, while I understand the XK platform to be reliable overall, anytime I hear a new noise it definitely sparks some paranoia haha.
The car has just a little over 90k miles on it and hasn’t given me any issues, but it just recently started this odd sort of whine coming near the front of the engine bay.
I have an indie Jag mechanic scheduled to look at the car near the end of December, but I wouldn’t want to exacerbate any issues this sound may mean by driving it in the meantime.
Thanks in advance for the help!
Old Nov 26, 2020 | 03:37 PM
I originally attempted to attach the video from my phone but no luck.
Now that I’ve uploaded it to my YouTube channel here’s the actual sound:
Old Nov 26, 2020 | 03:58 PM
Cee Jay's Avatar
Does the noise change with engine speed?
Sounds like a bad bearing, maybe on an idler pulley, but also maybe on the water pump or other accessory.
If the sound DOES change frequency with differing engine speeds, get a funnel or a stick and see if you can hear where the sound is coming from.
Chances it's from the front end, as I said. Pulleys or bearings.
Old Nov 26, 2020 | 04:21 PM
NBCat's Avatar
Remove the accessory and supercharger drive belts then restart the engine to see if the noise is still present.
Old Nov 27, 2020 | 02:57 PM
George05's Avatar
Good advice Sir
Old Nov 27, 2020 | 06:01 PM
Thanks for the replies everybody! I’m unfortunately pretty busy for the next few weeks so won’t really have time to get down in the engine bay but I’ll let you all know if something comes of it.
for added info, the previous owner had the water pump & thermostat replaced a few thousand miles before I bought the car and gave it a small-pulley upgrade in the process.
I don’t know if that affects anything else in there, but I suppose it could?
Old Nov 27, 2020 | 06:03 PM
to answer another question, the sound does *not* change with the RPM, it seemed like a steady constant instead.
Old Nov 27, 2020 | 07:07 PM
Cee Jay's Avatar
If the pulley was put on by someone and that someone didn't do it the proper way, you may have a misaligned belt, which could mess up a whole bunch of stuff. A looser belt (cuz smaller pulley) could also be a culprit.
Old Nov 29, 2020 | 04:02 AM
MarkyUK's Avatar
Doesn't to me sound like a belt or pulley alignment issue, doesn't also sound like a isolator/coupler issue.
Can you advise if the SC oil's ever been changed? If not I think it's overdue with those miles and your SC is running on dry and what you can hear is bearing noise.
My 2014 with 56k miles is going in to have the oil and nose replaced tomorrow (as well as all new ancillaries and a 6% ss bolt on pulley) I'll play your clip for my mech when there and let him guess.
Old Nov 29, 2020 | 04:45 AM
MarkyUK's Avatar
Duplicate post
Old Nov 29, 2020 | 06:44 PM
Stuart S's Avatar
Another possibility is the supercharger snout (coupler). It's a common repair. See:
https://www.jaguarforums.com/forum/x...harger-228083/
Old Nov 29, 2020 | 08:04 PM
mhminnich's Avatar
If it isn't changing with rpm, that tends to discount the rotating bits. That would have me looking for a squealing vacuum leak.
Another thought would be the intercooler pump.
xkrmaxer
Nov 8, 2020 02:22 PM
pwpacp
Nov 19, 2017 07:07 PM
10 XF Premium
Sep 1, 2017 01:18 PM
doughball2014
Nov 5, 2014 05:04 PM
