Rear wheel BHP on ......
Old Mar 21, 2014 | 05:10 PM
muncher's Avatar
Default Rear wheel BHP on ......
Hi All. Does anyone know what the rear wheel bhp is on supercharged 4.2 xkr?
I have read 420bhp. But is that at the fly wheel?
Would like to know how many horses have escaped from mine.
.....Cheers.
Old Mar 21, 2014 | 05:44 PM
Cambo's Avatar
Every dyno is different but anywhere between 320 & 340 at the wheels is about normal for a stocker, depending on weather, fuel, and general condition of the engine.
The 420 is the flywheel number.
Old Mar 21, 2014 | 05:45 PM
richzak's Avatar
.....Cheers.
Jaguar XKR supercharged 4.2-liter V-8 touts a supercharged engine that makes 420 horsepower and 413 lb-ft of torque. Don't know if its the front end or rear wheels. This info from a auto write up.
Old Mar 21, 2014 | 06:13 PM
muncher's Avatar
Thanks for quick reply. I had a dyno baseline run done today before I do pulley mod. I am getting 368bhp at rear wheels. I was curious how this stacked up. So if 320-340 approx. is normal then I am happy so far. Can't wait for the pulley mod.
Old Mar 21, 2014 | 07:01 PM
Cambo's Avatar
Like I said, every dyno is different. 368rwhp seems pretty optimistic for a stock engine to me!
I would be less worried about the actual number, the main thing is to see the improvements for the modifications.
Old Mar 21, 2014 | 07:11 PM
jahummer's Avatar
In what gear? I was getting 373 in 4th gear after an exhaust mod and around 415 in 5th.
Old Mar 21, 2014 | 09:12 PM
muncher's Avatar
It was in 3rd gear. As cambo351 says it will at least give me a good base line to work from. I will be using the same dyno and same conditions for the next run once the pulley has been added.
Old Mar 22, 2014 | 07:30 AM
jagtoes's Avatar
Isn't the rule of thumb about 17% reduction at the rear wheels.
Old Mar 22, 2014 | 09:28 AM
ccfulton's Avatar
17% give or take, maybe even a little less with these cars that have a lockup torque converter.
+1 on the dyno being a comparison tool and trying to match the conditions as exactly as you can. The absolute numbers are near meaningless.
Old Mar 22, 2014 | 09:50 AM
Mikey's Avatar
17% is a pulled out of the air 'generalization' that might have been accurate for one car on one day. There is no fixed number that applies in all cases.
Old Mar 22, 2014 | 10:14 AM
amcdonal86's Avatar
I don't understand what difference the gear makes. Can someone educate me?
dsnyder586
Dec 29, 2024 07:39 PM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
