Replaced Timing Chain
Old Mar 13, 2018 | 09:22 AM
Gom's Avatar
Gom
Default Replaced Timing Chain
Recently had to replace the timing chain at 33K on a 2011 XK Coupe. Lots of $$$$ any comments. I still LOVE this car.
Old Mar 13, 2018 | 09:32 AM
NBCat's Avatar
Was the replacement necessary due to chain guide wear?
This is also the forum for the X100; you have an X150.
Old Mar 13, 2018 | 09:41 AM
Gom's Avatar
Gom
Thanks for the quick reply. I should have posted as X150. I do not know if it was from chain wear. I was surprised that this happened at 33K as was my Service Advisor at my dealership.
Old Mar 13, 2018 | 09:44 AM
NBCat's Avatar
What diagnosis was performed to determine the timing chains needed to be replaced?
Old Mar 13, 2018 | 09:47 AM
I've moved your post to the X150 section.
Any background info on the fault?
Old Mar 13, 2018 | 10:45 AM
Primary and/or secondary?
Tensioners were an issue on the previous XK8 4.0 model and finally resolved with the fourth generation on the 4.2 litre. Chains were rarely reported as an issue in isolation.
With a chain issue on a 5.0 litre, you must have had to replace sprockets and tensioners too?
Old Mar 13, 2018 | 11:35 AM
Cee Jay's Avatar
"Dealer Advisory". Why would there be any diagnosis?
Old Mar 13, 2018 | 11:57 AM
Ranchero50's Avatar
Easy money, for the service writer.
Old Mar 13, 2018 | 05:28 PM
makecopies's Avatar
? Is this common in these cars
Never heard of a 4.2 that need a timing chain replaced
Old Mar 13, 2018 | 06:29 PM
NBCat's Avatar
The OP appears to have a 2011 5.0 litre car.
Old Mar 13, 2018 | 09:59 PM
amcdonal86's Avatar
Sounds like you just got hosed. Which dealer? Rosenthal Tysons? Chantilly?
slanham
General Tech Help
Feb 1, 2014 06:34 PM
linconlsv8
28
Feb 20, 2012 12:37 PM
kdross
Sep 9, 2010 08:08 AM
