Sooo.... I got carjacked....
Old Aug 3, 2022 | 03:16 PM
  #81
bogdanfilip's Avatar
Originally Posted by pk4144
DONE AND PAID.
A little over $32,000.
Works for me.
A few weeks ago it was my lucky day …
thank for taking such good care of the car .
on the outside it looks bad the runs and drives like new
Old Aug 3, 2022 | 06:52 PM
  #82
Cee Jay's Avatar
Well, holy shitballs. Nice to see the beast NOT torn for parts.
Old Aug 3, 2022 | 07:36 PM
  #83
pk4144's Avatar
WHAT????????
Old Aug 3, 2022 | 07:38 PM
  #84
pk4144's Avatar
Originally Posted by bogdanfilip
a few weeks ago it was my lucky day …
On the outside it looks bad the runs and drives like new
do you want the service records?
Old Aug 3, 2022 | 07:40 PM
  #85
pk4144's Avatar
I'm still in shock. I've attached a summary I used for the insurance company of the work done.
FYI, the rear crossover pipe was replaced about a month prior to the theft.
My next two issues would have been:
- keep hunting the phantom power drain (gotta start that car dialy)
- supercharger is getting a little knock-y.
Old Aug 3, 2022 | 07:44 PM
  #86
pk4144's Avatar
Here ya go:
2010 JAGUAR XKR SHOP WORK
(DOES NOT INCLUDE MAINTENANCE - TIRES, OIL, FILTERS, FLUIDS)
09/16 REPLACE #1, #6 FUEL INJECTOR
REPLACE FRONT LATERAL ARM BUSHINGS
REPLACE #2 COIL
10/16 INSTALL SPACER AND O-RING TO ELIMINATE WHISTLE IN FRONT CLIMATE SYSTEM
REPLACE REAR TRUNK LID TAILLIGHTS DUE TO DEFECTIVE FOGLAMPS
04/17 REPAIR SUPERCHARGER USING SNOUT KIT
REPLACE A/C DRAIN TUBE ASSEMBLY
REPLACE TRANSMISSION MOUNT (1)
06/17 REPLACE ELECTRONIC DIFFERENTIAL- UNIT SHIPPED FROM UK
03/18 REPLACE RIGHT AND LEFT REAR WHEEL BEARING
REPLACE BOTH UPPER FRONT CONTROL ARM BUSHINGS
REPLACE SWAY BAR LINKS
04/19 REPLACE BOTH FRONT WHEEL HUB-BEARING ASSEMBLIES
REPLACE ENGINE MOUNTS
10/19 REPLACE CONTROL MODULE
REPLACE FRONT SWAY BAR BUSHINGS
REPLACE LOWER REAR CONTROL ARMS AND BUSHINGS
REPLACE HEADLAMP CONTROL MODULE
11/20 REPLACE COOLANT FAN AND SENSOR ASSEMBLY
REPLACE THERMOSTAT ASSEMBLY
REPLACE WATER PUMP
REPLACE RADIATOR HOSE (2)
REPLACE/REPAIR WIRING FOR CONVERTIBLE TOP
REPLACE CONNECTOR PIN ASSEMBLY FOR CONVERTIBLE TOP
REPLACE BOTH FRONT INNER STRAIGHT ARM BUSHINGS
06/21 REPLACE BOTH FRONT ADAPTIVE HEADLAMPS
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
REPLACE FRONT CURVE ARM BUSHINGS
08/21 REPLACE A/C COMPRESSOR
10/21 REPLACE COOLANT MANIFOLD, REAR HEATER HOSES
TOTAL: $48,888.59
Old Aug 3, 2022 | 08:17 PM
  #87
Tracee's Avatar
Got that pesky "A/C Drain Plug" (duck-bill) replaced; good move...
Old Aug 3, 2022 | 09:16 PM
  #88
89 Jacobra's Avatar
Active Streak: 30 Days
That's absolutely Cool for everyone involved! The previous owner got a great price for his loss. And the 1st in line got a great car to boot. Some times things have a way of working out for the best. Might want to keep an eye out for the bolt of Lightning though??? Just sayin.
Jack
Old Aug 3, 2022 | 11:20 PM
  #89
pk4144's Avatar
$680 out of pocket and worth it.
Old Aug 4, 2022 | 06:54 AM
  #90
guy's Avatar
guy
Here ya go:
REPLACE #2 COIL
REPLACE WATER PUMP
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
TOTAL: $48,888.59
That all looks like “maintenance” to me.
Old Aug 4, 2022 | 09:47 AM
  #91
ram_g's Avatar
Replacing 2x headlamp units at USD ~3,600 each is "maintenance"? Wow.
As for most of the rest, that would be highly dependent on the mileage on the car at which point these activities became necessary. It may have been mentioned earlier in the thread as to how many miles the OP had on his car but I must have missed it.
Being an active follower of multiple car marque forums (all of them "cars with personalities" BTW) it is interesting to me as to the level of problems and consequent maintenance/repairs that owners find to be acceptable. I think Jaguar owners are particularly tolerant...
Old Aug 5, 2022 | 12:21 AM
  #92
pk4144's Avatar
...not to mention a brand new REPLACEMENT DIFFERENTIAL which was shipped over from England. And that supercharger rebuild. And the taillights (as well as the headlight assemblies and also surprisingly pricey).
Old Aug 5, 2022 | 09:01 AM
  #93
Man thanks a lot for all the info
I’m sooooo happy to see that huge list ))
yeah , I’m so happy with the car , drives amazing …
now I hope I can find a good body shop that can fix that damage .
Old Aug 5, 2022 | 10:38 AM
  #94
lear60man's Avatar
Well, that was not expected.
Old Aug 6, 2022 | 11:40 AM
  #95
jahummer's Avatar
How did you acquire this car?
Old Aug 6, 2022 | 11:47 AM
  #96
jahummer's Avatar
It's the new generation, 2010+ JLR models which are the most problematic and more so Land Rovers, even with the same failed parts as their cousins, Land Rover steps it up with even more systems subject to fail. They're more reliable than Audi's though where top to bottom, front to back rebuilds are part of the routine maintenance schedule...
Old Aug 6, 2022 | 12:04 PM
  #97
salvagebid.com
bklynchris
Dec 8, 2021 08:46 AM
rscultho
May 31, 2014 01:30 PM
Skeeter
Jul 31, 2012 03:44 PM
Honza1
Dec 20, 2009 10:42 AM
05xkrconv
May 6, 2009 08:32 PM
