What did you do to your X150 today?
Old Oct 21, 2018 | 11:00 PM
  #501
steve_k_xk's Avatar
For a change nothing was done on my xk I simply drove it and parked the car haha ... although found a suitable replacement during my morning walk !!
Attached Thumbnails What did you do to your X150 today?-img_20181022_060601.jpg
Old Oct 21, 2018 | 11:57 PM
  #502
Cambo's Avatar
Originally Posted by jahummer
The original has been superseded multiple times but I see 2 current parts listed, C2P18816 which appears exclusive to the 4.2 motor and C2P25607 which is listed for 5.0 and 4.2 motors...which did you come up with? I'd like to do this next week, even though I've no issues with mine, just as an inexpensive precaution.
OK so having looked at the CCF of both the 4.2L and the 5.0L, neither version has the field "INSTRUMENT_4_LOW_COOLANT_WARNING" in use.
This tells me two possibilities;
#1 the low coolant warning function is built in to the instrument cluster software and is not a feature that can be enabled or disabled. The feature may or may not be present in the 4.2L cluster.
#2 the switch function is closing the circuit to trigger the warning (which is a little counter intuitive) in which case, grounding the pin on IP032/14 would/should trigger the warning.
I found this in the 5.0L workshop manual Engine Cooling section "If the coolant level in the expansion tank decreases below a predetermined value, the level sensor connects a ground to the instrument cluster, which activates the appropriate warning. For additional information, refer to 413-01 Instrument Cluster."
When you check section 413-01, it's contradictory... "A warning message is also displayed in the message center if the coolant in the expansion tank falls below a given level. The instrument cluster is hardwired to a level switch in the expansion tank with feed and return connections. If the switch opens the instrument cluster detects the low coolant level and displays the applicable message."
So I guess it's possible, but i'd have to pull out the instrument cluster and test it, also have to try to find the right terminals for that connector...
Or get hold of a 5.0L and try unplugging the sensor, and grounding out the wire at the sensor. Actually both tests would be a good idea...
Originally Posted by Patrick Wong
I bought C2P25607 in April 2018. It comes with a higher pressure cap which I did not use. It also comes with the fluid level sensor which I removed.
Any chance you can post up some detailed pics of the sensor, and confirm how it functions? normally closed, normally open, etc?
Old Oct 22, 2018 | 02:05 AM
  #503
u102768's Avatar
Originally Posted by MarkyUK
... but I don't consider a CTEK a normal charger.
The attachment points for the Jaguar branded CTEK are in this PDF. As others have said, it is to do with the battery management system but in reality it does cope OK if you just wire it up to the negative terminal.
File Type: pdf
File Type: pdf
Old Oct 22, 2018 | 02:18 AM
  #504
MarkyUK's Avatar
Thanks for the attachments, I'll see if i can get the longer leads to do it properly, will naturally look at CTEK first as am sure from Jaguar it's 4 x the price!
Am guessing this is the thing, but the lead doesn't look much longer than the stock one:
https://www.ebay.co.uk/itm/CTEK-8-4m...aDv~:rk:1:pf:0
Old Oct 22, 2018 | 07:19 AM
  #505
jagtoes's Avatar
I used the module chassis on the right side of the battery to ground out the negative Ctek wire. Any one of the screws will work just check the ground with a meter.
Old Oct 22, 2018 | 07:39 AM
  #506
110reef's Avatar
Originally Posted by 110reef
Clay barred my car over the weekend.
Bought new brake pads which will be next weekend's job.
Installed my new ceramic akebono brake shoes this weekend. Smooth.
Which leads me to a question:
Is there no low brake sensor on the Jag? There were no pad sensors. I ask because one pad was down to bare metal, but no warning from the car.
Old Oct 22, 2018 | 08:55 AM
  #507
MarkyUK's Avatar
On my X100 there were only wear sensors on the fronts IIRC?
So do tell where you got your Akebono's from with a link and part numbers...I can't buy them this side of the pond sadly
Old Oct 22, 2018 | 10:25 AM
  #508
110reef's Avatar
I got them on ebay:
Of course I have a 2008, so your parts may be different.
https://www.ebay.com/itm/29277863035...m=292778630356
https://www.ebay.com/itm/29277863061...m=292778630618
Old Oct 22, 2018 | 11:55 AM
  #509
jahummer's Avatar
The price was USD106 plus shipping at parts.com
ended up ordering T2R25157 per Jaguar. Will be here tomorrow morning.
Old Oct 23, 2018 | 06:58 PM
  #510
kj07xk's Avatar
Default Baby finally got a bath.
All shiny again.
Old Oct 23, 2018 | 09:12 PM
  #511
Cee Jay's Avatar
Mine's shiny again also:
Old Oct 23, 2018 | 09:51 PM
  #512
pwpacp's Avatar
As I recall the wear sensors are opposite sides of the vehicle. Right side on rear pads and left on the front.
Maybe someone else can detail to be certain though.
Old Oct 23, 2018 | 11:06 PM
  #513
Patrick Wong's Avatar
Originally Posted by Cambo
...Any chance you can post up some detailed pics of the sensor, and confirm how it functions? normally closed, normally open, etc?
Here are three photos. The resistance across the two pins in the socket is infinite. I have no idea how this sensor works, it fits into a hole in the reservoir but does not appear to have any contact with the actual coolant, since it is possible to remove the sensor without causing a leak.
The sensor is almost 3-1/2 inches long.
Two pins in the wiring harness socket
Here is the tip of the sensor, looks like a wire running the full length.
Old Oct 24, 2018 | 05:17 AM
  #514
Ngarara's Avatar
... I have no idea how this sensor works, it fits into a hole in the reservoir but does not appear to have any contact with the actual coolant, since it is possible to remove the sensor without causing a leak.
There's nothing in the workshop manual to explain its operation, but it looks similar to the oil-level sensor. That is ultrasonic, so this may work the same way, i.e. bouncing ultrasonic pulses off the liquid/air boundary.
Old Oct 24, 2018 | 08:27 AM
  #515
MarkyUK's Avatar
Well my battery is defo on it's way out, with 500 miles of driving with no lights on (and a hardly listened to the stereo, preferring the soundtrack of my engine!) it gave me a 'low battery' message.
So will be replacing with my spare (fully charged ) type 19 when returning home on Saturday morning, for now it's on CTEK charge and is getting as far but no further than 6. So it will take a charge but simply not hold it.
Also notice that the passenger seat backrest doesn't move as far forwards as the drivers one, it reclines fine, I don't think it's the common problem with seats but suspect just a motor that needs replacing. Any suggestions would be appreciated...in the meantime will do a few forum searches
Old Oct 24, 2018 | 09:02 AM
  #516
110reef's Avatar
There were none on my car. At least not attached to the shoes. I changed all four wheels.
Old Oct 24, 2018 | 09:25 AM
  #517
shemp's Avatar
shoes??
Interesting because they show up on the parts list for your car. Item #16 :
https://www.jaguarlandroverrenoparts...nt-brakes-scat
Old Oct 24, 2018 | 11:49 AM
  #518
Sean W's Avatar
Originally Posted by shemp
shoes??
Per the service manual, there are no wear indicators on the front or rear wheels.
Old Oct 24, 2018 | 12:06 PM
  #519
Sean W's Avatar
Deleted comments as they were repetitive of post 502
Last edited by Sean W; Oct 24, 2018 at 01:57 PM. Reason: Deleted comments as they were repetitive of post 502
Old Oct 24, 2018 | 12:36 PM
  #520
110reef's Avatar
shoes??
Shoes, pads, its all the same.
Maybe it is only on 355MM brakes. I don't know if mine are 355MM or not, but there are no sensors on the pads. That I can attest to.
