What Part Is This???
Old Mar 9, 2021 | 10:31 AM
Luis LCG's Avatar
Default What Part Is This???
i had received a P003E error and learned that there is a LR TSB for this related to an oil restrictor issue, this restrictor is in the front of the cylinder head just below the input phaser.
it seems the CPS Camshaft profile switching (CPS) solenoids has some kind of insert which I suspect may also be part of the oil flow process. Does anyone know as i cant seem to find any details.
Old Mar 9, 2021 | 10:32 AM
Luis LCG's Avatar
The item with the black circle, i cant seem to find any details on this. Does anyone know?
Old Mar 9, 2021 | 05:32 PM
George05's Avatar
That sensor in blue in first photo is it located at rear of engine ? If so could be the boost sensor
Old Mar 9, 2021 | 05:52 PM
The sensor in the top image is one of the Camshaft Profile Switching Solenoids. Here are the possible causes of the P003E code:
Here is the relevant extract from the Workshop Manual describing the Camshaft Profile Switching Solenoid operation:
Old Mar 10, 2021 | 07:57 AM
Luis LCG's Avatar
Thanks and agree but the workshop and other docs do not describe what part this is or its function. The workshop has the image of the component but does not reference it. My research yesterday indicates that it might be an oil control valve or a one way control valve. im looking to understand the function of this device to see if it could be a possible cause of my code.
Old Mar 10, 2021 | 09:12 AM
The description of the Camshaft Profile Switching Solenoids in the Workshop Manual page I posted in #4 couldn't be any more succint.
Old Mar 10, 2021 | 10:57 AM
Luis LCG's Avatar
Thanks, i am well aware of how the CPS works, my questions is what does the image i had put in above do, whats its function. Below is the text and it does not state what this device does. That is what i am looking to determine, what is this device, is it a check valve or a one way valve and what happens if there is an issue with this device? "The CPS (camshaft profile switching) system switches the intake valves between two cam profiles which have different lift
and period. The low lift profile improves driveability and emissions at lower engine speeds. The high lift profile improves
power and torque output at higher engine speeds.
The intake camshafts have three lobes for each valve. The two outer lobes have identical profiles that produce the high lift of
10.53 mm (0.415 in.). The central lobe produces the low lift of 5.50 mm (0.217 in.). Switching between cam profiles is
performed by a switchable tappet on each intake valve. The switchable tappets are operated by engine oil controlled by a
CPS solenoid on each cylinder head. Operation of the CPS solenoids is controlled by the ECM.
The CPS solenoids control the supply of engine oil pressure to the locking pins in the switchable tappets, to switch the
tappets between the two cam profiles.
A CPS solenoid is installed on the rear of each cylinder block. Each CPS solenoid has a pintle installed in a sleeve, which
incorporates oil inlet and outlet holes. The sleeve is installed at the junction of oil galleries in the cylinder head, with the oil
inlet and outlet holes aligned with the galleries. Movement of the pintle in the sleeve controls a connection between the oil
galleries. When the CPS solenoid is energized, the pintle connects an oil supply gallery to the gallery along the outboard side
of the switchable tappets. When the CPS solenoid is de-energized, the oil gallery along the outboard side of the switchable
tappets is connected to drain.
Old Mar 12, 2021 | 05:05 PM
Luis LCG's Avatar
This is the part I’m trying to get details on. Not the CPS but part of the oil flow from CPS to the tappets.
VancouverXJ6
May 20, 2023 07:02 AM
Freddy J
Jan 25, 2021 09:29 AM
Ray Ray
Aug 31, 2020 04:47 AM
peppersam740
Jan 5, 2020 03:50 PM
Michael Star
Jul 3, 2013 07:55 PM
