Why do I have to use key slot
Old Apr 3, 2019 | 07:19 PM
‘Oleguy's Avatar
Default Why do I have to use key slot
I have an ‘08 Portfolio XKR. I use to be able to keep the key in my pocket and it would recognize the key.
I tried using the key slot as I had never used it before. Now it wants it in the slot all the time.
Is there a simple fix for this?
Old Apr 3, 2019 | 07:39 PM
jagtoes's Avatar
Did you replace the battery in the key fob
Old Apr 3, 2019 | 07:42 PM
‘Oleguy's Avatar
No. Put will definitely do that. How often do the need replaced? Yearly? Thanks.
Old Apr 3, 2019 | 07:46 PM
jagtoes's Avatar
Once a year is usually the norm.
Old Apr 3, 2019 | 08:45 PM
Stuart S's Avatar
CR2032 battery life varies greatly depending on how long it sat on the shelf before you bought it, the manufacturer, and how often it's used. I recommend that you never buy them online because you have no way of knowing if it's genuine or a cheap Chinese knock-off and you can't verify the date code. I always buy a 2-pack of brand name CR2032 batteries at a local chain drug store so I can check the date code. Changing the battery is easy and no programming is needed. Keep the other one in your glove box as a spare for when you get the dashboard warning that your keyfob battery is low.
Old Apr 4, 2019 | 05:37 AM
‘Oleguy's Avatar
Thanks you gents. I don’t remember getting a battery low messsage on the dash readouts. But then I don’t remember what was for dinner last night.
I will get a Duracell 2 pack and change them both out
Old Apr 4, 2019 | 05:51 AM
SickRob's Avatar
I can't resist. Obviously your car is female and once you stuck it in it won't settle for just having it in your pocket.
Old Apr 4, 2019 | 07:27 AM
‘Oleguy's Avatar
Very demanding. We will see how she likes it with new alkaline copper top batteries.
Old Apr 4, 2019 | 10:51 AM
The rear of the Smartkey case wasn't applying firm pressure on the battery with the early models and was subsequently redesigned. Assuming you use premium CR2032 batteries, a new case could get over this issue.
I fitted new cases to the remotes on my 2007 XK when I found out they were only about one tenth the cost of a new remote. If you do this, use only OE Jaguar - there's some Chinese rubbish listed on ebay etc.
Old Apr 4, 2019 | 11:42 AM
Ranchero50's Avatar
I've had some batteries last a month, others a couple months. You make a quarter year and you're overdue to replace it IMHO.
Old Apr 4, 2019 | 12:43 PM
Cee Jay's Avatar
I don't know about all THAT...
I've replaced the batteries in my smart key one time, about three years after I purchased it. THAT was from a Lease Return, and I assume it had fresh batteries installed prior to the sale. I did get one new remote when I thought a grand kid lost one, but later found it under the PAX seat.
The current battery is probably two years old now, the one that was originally in the new key I got from Jaguar. The other two keys still have the ones from three years ago, and both still work.
Maybe I'm just lucky? I have had OTHER batteries in remotes go bad quick. My F150 specifically, I need to change THAT one twice a year.
Old Apr 4, 2019 | 02:19 PM
shemp's Avatar
My remote battery is about 1.5 yrs old but I do keep mine on the CTEK when not in use
Old Apr 4, 2019 | 03:34 PM
Don-T's Avatar
Wow! How do you hook up the Ctek to that little bitty battery?
Old Apr 4, 2019 | 03:41 PM
Stuart S's Avatar
My CR2032 experience is like Cee Jay's. They last for years in both my XKR and XJ. As I previously said, buy them locally, name brands only, and check the date code. The fresher the battery, the longer it will last.
Old Apr 4, 2019 | 04:33 PM
‘Oleguy's Avatar
Ok. I bought the car Jan of ‘18. It did have new batteries installed then because I couldn’t get it unlocked.
This year when I got in the car it wanted the slot. I had the car display ‘doesn't recognized key’. I’ll get new batteries.
Thank guys!
Old Apr 4, 2019 | 08:40 PM
Stuart S's Avatar
If your Smartkey fob is in your pocket and blocked by your sunglasses or anything else, it might not be recognized if its battery is weak.
Old Apr 4, 2019 | 09:51 PM
jagtoes's Avatar
Thank guys!
Just a FYI but cell phones and credit cards in a wallet will block the key fob signal.
Old Apr 14, 2019 | 09:31 AM
‘Oleguy's Avatar
Default New Batteries Do Matter
I finally bought new 2032 Lithium’s and everything is normal now. Key in pocket or cup holder push start and go. One of the old was showing slight corrosion/leakage. I guess this will be a regularly 6 month replacement item.
carzaddict
Apr 21, 2023 07:28 AM
DAMAN
General Tech Help
Apr 6, 2019 10:47 AM
Zhangsta
Jun 8, 2017 09:14 PM
DaleD
Jul 31, 2010 03:34 AM
