Xkr Portfolio springs
Old Sep 25, 2017 | 03:19 AM
Jaguarxkr01's Avatar
Default Xkr Portfolio springs
Hi all,
Does anyone know if my MY2009 (2008)Xkr Portfolio has lower ride height than a standard Xkr?
I would like to lower it a bit but am unsure of what springs to purchase.
Many thanks
Grant
Old Sep 25, 2017 | 06:01 AM
steve_k_xk's Avatar
Actually Cameron (Cambo) and myself swapped out his portfolio suspension today for xkr-s shocks & springs .
The xkr and xkr portfolio have the same ride height its the xkrs that sits lower
Attached Thumbnails Xkr Portfolio springs-img_20170925_125533.jpg   Xkr Portfolio springs-img_20170925_143212.jpg
Old Sep 25, 2017 | 07:12 AM
Cambo's Avatar
Yeah, was a big day.
The XKR Portfolio had the same ride height as the regular XKR.
According to the book, the 4.2L XKR-S was 10mm lower at the front and 15mm lower at the rear than the XKR, those are the springs & shocks we put in today.
Old Sep 25, 2017 | 07:28 AM
Cambo's Avatar
And fwiw here is the XKR-S rear spring compared to the regular XKR one
Old Sep 26, 2017 | 12:59 PM
Panthro's Avatar
They look a little bit like the H&R lowering springs
Old Sep 26, 2017 | 01:45 PM
guy's Avatar
guy
Attachment 203311
Attachment 203312
OK, need to ask:
Did you change up the control arms too? Or did the alignment satisfy you?
I have been wondering on how to proceed with my next bushings replacement and have been considering changing the whole lot (including springs and dampers)
Damn I wish I lived in your neck of the woods...
Old Sep 26, 2017 | 06:33 PM
Cambo's Avatar
Originally Posted by guy
OK, need to ask:
It had to go for an alignment as we changed the rear track rods (split boots / leaking ball joints).
I gave the workshop the factory specs for the "XK Dynamics Pack Option and XKR-S - 2009 up to 2010 MY" and asked them to set it according to that.
When we picked up the car the tech told me that the settings were "maxxed out on the pins" so basically it ran out of adjustment, and this was the best they could do...
To be honest i'm not thrilled about that and will look into how to resolve the problem.
The rubber boots on the wishbones are all starting to split, so sometime down the track it'll need a full set of wishbones.
Biggest gripe for me right now is the camber on the rear axle, which as you know is not adjustable. My left rear is -1°05', the right rear is -0°53', and that cannot be "fixed" easily.
For the front adjustment being "maxxed out" I have an idea. There are two types of cammed bolt for these cars, one is listed for "4.2L Supercharged" the other is "except 4.2L Supercharged", so it's worth checking what the difference is between these two, since the 5.0L Supercharged cars would have a different bolt than what's in mine now...
Then there's the "special" rear lower wishbones from the 4.2L XKR-S, not sure what makes them so special, guess i'll find out soon enough... we can see what the camber looks like after those go in, along with new rear upper wishbones, and then start thinking about shims or something...
Old Sep 27, 2017 | 11:48 AM
Panthro's Avatar
You could take out the control arm bolts in the rear and elongate the holes in the tabs so the rear camber can be adjusted. It's what some of the Lincoln LS guys do when they install lowering springs. The LS camber bolt kits for the front might fit the rears as well, but I can't confirm. Just a thought
Old Sep 28, 2017 | 12:22 PM
Tervuren's Avatar
Do you have pictures of it put together on the ground yet with the new springs?
Old Sep 28, 2017 | 12:32 PM
steve_k_xk's Avatar
I'm sure Cameron has more pixs
Old Sep 28, 2017 | 03:42 PM
Cambo's Avatar
This was taken the day after the install.
I don't have any better pics right now sorry.
