2001 jaguar xk8
Old Jan 19, 2012 | 08:51 PM
jagluva's Avatar
Question 2001 jaguar xk8
I have a problem. I need a new engine. I want to find a rebuild kit, but I haven't had any luck. I was told that I could replace the Jaguar engine with a small block Chevy 350, but I don't know if I will need any extra parts to make that work. uuuuggghhh!!!!!
Old Jan 19, 2012 | 11:52 PM
avos's Avatar
Have a look here:
https://www.jaguarforums.com/forum/x...nto-xk8-61020/
Old Jan 20, 2012 | 08:55 AM
motorcarman's Avatar
A good used engine will bolt into your car.
XJ8 (1999 to 2003) or XK8 (1999 to 2002) will drop in with NO mods required.
bob gauff
Old Jan 20, 2012 | 09:02 AM
Need a new engine.................a drastic solution, so what's the problem with it?
Used Jaguar values will be very different in the US than they here in the UK but putting another manufacturer engine in has still got to reduce the value and make it more difficult to sell.
Old Jan 20, 2012 | 07:56 PM
oldjaglover's Avatar
or, could he get a used Lincoln LS 3.9 which is virtually identical to the AJV8? Gotta be cheaper.
Old Jan 21, 2012 | 12:12 AM
Reverend Sam's Avatar
You can find a used Jag engine for $1500. That would be the easiest thing to do. Putting in anything else is going to cost more than that because of all of the mods required.
Old Jan 21, 2012 | 08:36 AM
Bamaman's Avatar
Check Car-Part.com which is a website that salvage yards all over the country subscribe to.
Put your car's description in, and your geographic location. You'd be surprised how many used engines are available.
Get on the phone and offer them less than the posted price--and see if they'll bite on your offer. I've found some will deal with you.
If you go that route, just make sure the engine has the correct metal secondary camshaft tensioners, metal thermostat housing and metal impeller water pump before installing.
Old Jan 21, 2012 | 07:10 PM
jagluva's Avatar
bob gauff
Uh, Thanks?
Old Jan 21, 2012 | 07:11 PM
jagluva's Avatar
Uh, Thanks?
I couldn't find one of those either :-(
Old Jan 21, 2012 | 07:13 PM
jagluva's Avatar
It ran hot and now there's an awful knocking sound in the engine.
Old Jan 21, 2012 | 08:07 PM
test point's Avatar
Replace the engine with an used one.
I would challenge the comment above about car-parts '. . . some will deal with you'.
They will ALL deal with you.
Parts sitting in their inventory have no value. They will sell to move.
Old Jan 22, 2012 | 04:14 AM
With replacement engines available at the sort of prices quoted in earlier replies, I probably wouldn't consider a rebuild. Parts prices mount up very quickly and with additional machining if the heads are warped is likely to top replacement engine cost and then some.
Out of curiosity alone, I'd be partially stripping it down to determine exactly what damage has been done with the overheating. It may not be as bad as you think.
Before going any further, if you're not sure what the 'knocking' is, post a video or sound clip.
Old Jan 22, 2012 | 03:15 PM
I'll say again, before you grab "any" AJV8 there is some research to be done about the matchup with your tranny. I have read from several sources that the tranny/engine match IS important and can be a problem.
Pristine97XK8Convertible
Sep 29, 2015 02:43 AM
celticpiping
Sep 18, 2015 06:17 PM
tony bosco
Sep 1, 2015 02:06 PM
plums
General Tech Help
Sep 1, 2015 06:34 AM
dpappyp
Aug 27, 2015 06:31 AM
