2003xk8 trunk?
Old Feb 15, 2013 | 10:23 AM
bcclew's Avatar
Default 2003xk8 trunk?
trying to help a friend out lost his manual. batt went dead cant seem to find out where key goes for manual trunk opening?also he teels me you cant open the trunk or gas fill door unless engs off and key is out of ignition? with batt dead i used a jump pack on to pos cable at under hood fuse box.ign off and key out would not open trunk or gas door.but i was able too start car with jump pack cked charging voltage good. next ? ileft the car runnig so he could charge the batt after this runs for awhile do you think that mode will reset?and trunk will open? thanks for any help
Old Feb 15, 2013 | 10:35 AM
WhiteXKR's Avatar
Keyhole is hidden between 'X' and 'K' on XK8 logo on the trunk lid or on XK8/R logo plate on trunk, depending on which year and model.
Old Feb 15, 2013 | 02:01 PM
Green Machine's Avatar
Exclamation
Be advised the lock will probably be stuck so you will need to squirt some lube in it. I had to apply some downward force on the trunk lib also to get the lock to release.
Old Feb 16, 2013 | 10:24 PM
H20boy's Avatar
Can't open gas cap, true, but you CAN open the boot (trunk) with ignition on and engine running.
Old Feb 18, 2013 | 08:58 AM
mapatton's Avatar
For MY2003, the trunk key hole is on the right side of the car. It is in the 4.2 emblem, just left of the wording. And yes you can open the trunk with key in ignition as well as running.
Old Feb 18, 2013 | 09:45 AM
steveinfrance's Avatar
Don't ever jump start from the positive terminal under the bonnet.
You were lucky to get away with that.
You can charge or use an external battery to operate the boot lock from those terminals.
Old Jan 12, 2020 | 11:20 PM
DLyttle's Avatar
Default XKR trunk key hole out of line with hole in badge
I have a 2005 XKR convertible. After wondering how to get into the battery if it was flat I found the key slot in the XKR logo but could not get the key in. Now I found the car has the mechanism fitted in the trunk and the key fits and works. The problem is the hole in the XKR logo is about 1 inch (25mm) out of line with the mechanism inside the trunk. The key hole should be about the centre of the X. The only option is going to be to move the logo to the right as it seems to be in the wrong place (even though it looks OK) Anyone tell me how the logo is attached or experienced this issue before? Cheers
Still has the blue paint on the key hole
The key hole should be about where the X is located
Can see the metal of the XKR badge when looking from the inside
Old Jan 17, 2020 | 02:58 AM
Originally Posted by DLyttle
..... Anyone tell me how the logo is attached .....
The badge is originally attached with 3M double sided tape. However, as there's evidence of remedial paintwork, it could have been glued back on.
magmedia
Aug 15, 2019 08:54 PM
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
