3rd brakelight removal
Old Feb 6, 2018 | 08:28 AM
Dercent's Avatar
Default 3rd brakelight removal
I need to paint the housing on 1999 xk8 3rd brakelight housing finish is chipped I believe that it pulls off but would like to know if for sure, would have to have this thing break a tab or something off. I guess I could mask everything off and carefully spray it. Dave in Tampa
Old Feb 6, 2018 | 10:38 AM
Dave,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your XK8.
Old Feb 6, 2018 | 11:44 AM
there are 3 nuts inside the trunk lid holding the 3rd brake light in place. Remove those and then carefully use a screwdriver to pry the tabs to release the cover
Old Feb 6, 2018 | 01:15 PM
avern1's Avatar
The third brake cover is held on by to clips about 2 inches in from each side. The best way to remove it is gripping it front and back about 2 inches in and pull up and rock gently. Don't force it but pull firmly. It will pop off. The first and last time I used a machine car wash the brushes knocked mine off.
Old Feb 12, 2018 | 06:10 AM
hichamaziz's Avatar
thank you for sharing .
Old Feb 12, 2018 | 05:05 PM
Dr. D's Avatar
Avern:
In general, I must disagree. I, like Sklimii would recommend using a flat blade through the 2 access rectangular openings in the base. Even then, I would suggest being careful not to break a plastic clip. Currently, 3 small bits of dbl sided tape hold my cover to the base.
Old Feb 12, 2018 | 06:52 PM
I forgot I happened to have a spare 3rd brake light so here are a few pics to help. I bought the 3rd as one of the tabs on the base (white part) of mine broke so the cover would not stay on. Easy swap and good to go. I did glue the broken tab back on but I don't trust the repairs
Attached Thumbnails 3rd brakelight removal-img_20180212_193652-1-.jpg   3rd brakelight removal-img_20180212_193658.jpg   3rd brakelight removal-img_20180212_193737.jpg   3rd brakelight removal-img_20180212_193806.jpg
Old Nov 23, 2018 | 04:06 AM
Anchorman's Avatar
How do you get the red cover off?
Dr. D
Dec 10, 2012 09:42 AM
AB22 Easy Tiger
Jun 2, 2012 10:39 PM
rodknock95
Jun 13, 2011 06:22 PM
XJ ate
May 8, 2009 12:47 PM
