97 XK8 tilt/retractable steering
Old Feb 28, 2015 | 04:43 PM
drk1074's Avatar
Default 97 XK8 tilt/retractable steering
I have had my 97 XK8 convertible for about 3 1/2 years and the tilt/retractable steering has never worked. Fortunately for me, it is stuck in the perfect driving position. The only sound it makes is when I push the joystick down toward the floor in either the auto of off position, and it is a single click coming from the passenger side. I removed the glove box today and discovered that the "click" is coming from a grey plug with about 95 tiny wires fed into it. The print on the side is F5SB-14A464-AA and underneath that is 001 6L 10A0 a. Any ideas? Thanks to all responders. Oh, and I did search the threads and found plenty of info, but I am still unclear on any action I might take to remedy the dead steering column. My car has a little over 50K on it.
Old Feb 28, 2015 | 05:03 PM
I've moved your post from the General Tech section to the XK8/R section for greater visibility/response
Old Feb 28, 2015 | 06:05 PM
drk1074's Avatar
Much obliged. And I like your car. Mine is the exact same colours.
Old Feb 28, 2015 | 06:18 PM
test point's Avatar
Common problem. My 'reach' doesn't work either. The 'tilt' is a lot easier to fix. The problem is generally a small cable, like a 3" speedometer cable between the motor and the gear unit that moves the column. Or . . . the small cable destroyed the nylon gear that it fits inside. Coventry West had a bunch of the cables made up as they are not, and never have been, available from Jaguar. The dealer's solution is to replace the steering column. Think that runs a little over a hundred dollars.
Here is a links: Tilt/Reach Steering Wheel Function
https://www.jaguarforums.com/forum/x...68/#post342851
If you fix the 'reach' problem please post pictures that I can follow to fix mine. I have the cable in hand awaiting your response.
[edit] Notice the Douglasville, GA. Lots of us Atlanta Area folks around. We have had one Atlanta Area 'cars - n- pizza event a few weeks ago and plan on a North Georgia Mountains Spring tour.
Old Feb 28, 2015 | 06:53 PM
drk1074's Avatar
Will do. My wife and I have a cabin in Suches, so I will keep my eye out for the spring tour dates.
Old Feb 28, 2015 | 08:21 PM
test point's Avatar
Know where Dial, Ga is? How about the Taccoa Riverside Restaurant? Not too far from Suches.
Old Feb 28, 2015 | 09:43 PM
drk1074's Avatar
We are very close to Dial. We are on Skeenah Gap Road just after you leave Union and enter Fannin. And we dined at the restaurant many years ago. I always notice their billboard on the way up.
Old May 7, 2015 | 05:25 PM
PatB's Avatar
The "reach" feature on my 2004 XKR is inoperative. The "tilt" works normally. I can hear the reach motor operating when I move the switch, but the column doesn't move. I can, however, manually pull the column aft and push it back forward to the tune of nylon on metal. Is this a cable problem or a gear problem, or something else?
RobertTheBloke
Sep 24, 2015 11:48 AM
ahunt4
Sep 19, 2015 09:49 AM
WhiteTardis
Sep 17, 2015 09:29 AM
Johnken
Sep 15, 2015 05:46 PM
Burdedw
Sep 12, 2015 10:39 AM
