ABS module and key fob repair
Old Nov 22, 2025 | 06:02 AM
jmstunts's Avatar
Default ABS module and key fob repair
Looking for recommendations on which vendor to use for ABS module repair, also looking for vendor that repairs key fobs 1998 xk8.....I am located in Myrtle Beach SC....USA
Jack M
Old Nov 22, 2025 | 07:24 AM
dibbit's Avatar
A clue as to where you are in the world might help with the recommendations...
Old Nov 22, 2025 | 08:07 AM
jmstunts's Avatar
updated, thanks
Old Nov 23, 2025 | 08:10 AM
garyag's Avatar
Default Module Master. Moscow, Idaho
repaired mine.
Old Nov 23, 2025 | 09:14 AM
motorcarman's Avatar
Keyfob Transmitter carbon contact restoration.
Amazon Amazon
Lots of info on soldering the circuit board for ABS module repair.
Old Dec 12, 2025 | 09:55 AM
drmike's Avatar
Oh dear sounds like some fob surgery is in my future
I shall report back once I have been brave.
Old Dec 12, 2025 | 12:27 PM
The transmitter comes apart easily and there are only 4 parts and the batteries.
The flexible button membrane can sometimes just be CLEANED but if the carbon is worn, then the new coating will work.
Old Dec 13, 2025 | 03:23 AM
drmike's Avatar
Cleaned up the internal bits. As you say it comes apart quite well. I had contact cleaner and so far all is well. Fob programmed and tested.
Time will tell if that was the problem - certainly a lot of dirt came off.
Old Dec 13, 2025 | 05:16 AM
Jon89's Avatar
Well done....
rrstl3
Jul 29, 2025 02:54 PM
cdma
Aug 31, 2024 09:19 AM
yellowbandit
Apr 29, 2024 06:54 PM
rande
Dec 17, 2023 03:13 PM
theusualsuspect
Sep 2, 2021 12:37 PM
