Alarm and no crank
recently bought a 1996 xk8 which the previous owner told me had suddenly stopped cranking and the alarm was going off. I only have one key and no fobs.
Having now got it the symptoms are
On unlocking the car with the key the Alarm goes off and doesn’t stop if the key is inserted into the ignition with 8 seconds.
The car will not crank but the dash lights come on.
The boot and petrol flap button do not work.
I am guessing this is the KTM.
So 2 questions.
If I buy a mongoose cable and SDd IDS v130 will this help with diagnosing ?
And if it is the KTM will IDS v130 be able to program a second hand KTM to my ECU ?
So 2 questions.
Both the boot release solenoid and the petrol flap solenoid are connected via the Security and Locking Module in the boot. Does the central locking work? Does the boot light come on when you open the boot?
To answer your question, yes IDS will help in diagnosing and is essential if you need to do an immobiliser setup. In the meantime I would read the codes using a dongle/Torque app and check you have power and ground where you are supposed to - check the fuses and relays before deciding you have a dead module.
You should always use the forum search when you are looking up a code:-
https://www.jaguarforums.com/forum/x...7-code-246247/
If I were you I'd open the ECM and look for any leaking or bulging capacitors. Lots of threads on the forum.
I now have IDS and the codes are numerous including
Anti lock braking C1155 and C1233
Restrain control module - No communication
A load of climate control ones
Engine control P1260 - I think this one is significant but do not really know how to further on this diagnosis
Instrument pack - U1260, U1261, B1238
Transmission control P1799, P1731, P0790, P1798
Where do you think I should go first ?
thanks
thanks
philwarner
Nov 29, 2015 05:11 PM
