Any ideas on this engine clunking noise?
Old Aug 23, 2025 | 01:47 PM
scottatl's Avatar
Default Any ideas on this engine clunking noise?
If anyone has any ideas on this noise I'd appreciate it. I used my stethoscope but the noise just travels through all the metal so I can't pinpoint it. The last thing I did on the engine was change the power steering pump, the noise did not come immediately, that was a couple months ago.
Old Aug 23, 2025 | 02:08 PM
michaelh's Avatar
Scott,
Try taking the serpentine belt off. It's OK to run the motor briefly without it.
Old Aug 23, 2025 | 02:14 PM
scottatl's Avatar
interesting, i will give that a try
Old Aug 23, 2025 | 03:00 PM
scottatl's Avatar
Great test, sounds find without it. Any next steps. my guess is a faulty power steering pump since that is relatively new. I don't look forward to redoing it.
Old Aug 23, 2025 | 03:31 PM
motorcarman's Avatar
I remember a TSB and checking cars for the bolts when I worked at the dealer.
Maybe the bolts are loose from the PAS pump replacement?
File Type: pdf
Old Aug 23, 2025 | 03:56 PM
scottatl's Avatar
Motocarman, what a memory!
so turning each item on the belt by hand does not give me a clank. The power steering pump, seems nice and tight, but i did notice something odd. The rotation seems a bit elliptical. The assembly is not loose, so I don't know how this could happen.
Old Aug 23, 2025 | 04:13 PM
xalty's Avatar
run it belts off
sounds like something’s getting hit in the timing case. guide material will do that until it gets crushed and falls into the pan
Old Aug 23, 2025 | 04:19 PM
scottatl's Avatar
Originally Posted by xalty
run it belts off
it sounds fine running it without the belt off, are you saying that running it longer without the belt on could solve something
Old Aug 23, 2025 | 05:02 PM
xalty's Avatar
it eliminates if it’s belt drive related or not
Old Aug 23, 2025 | 05:13 PM
michaelh's Avatar
The pulley looks to be off-centre. Weird, but that could càuse the tensioner to rattle as it deals with the resulting slight belt run length variation (QED)
Old Aug 24, 2025 | 10:25 AM
Gus's Avatar
Gus
Check this out before you begin replacing parts. JagRepair.com - Jaguar Repair Information Resource
Gus
juliam
Dec 18, 2024 03:17 PM
Kirk Morey
Jun 11, 2020 07:40 AM
reyesl
Mar 19, 2014 09:13 AM
Na5h
Feb 9, 2014 03:46 AM
