Auto Dimming Rearview Mirror Replacement
Old Aug 3, 2017 | 06:58 AM
  #281
Orthopedux's Avatar
I did a tutorial for it but it's in french, and I'm not good enough in english to translate here.
Connexion
Old Aug 9, 2017 | 01:01 PM
  #282
jimborino's Avatar
Connexion
I'm not sure I'm good enough in French to do so - but I know people
I would suggest posting it - perhaps in a separate thread with "Rearview Mirror Replacement - In French".
I suspect you are not the only Frenchman on here
Old Dec 29, 2017 | 04:26 PM
  #283
Yann's Avatar
Originally Posted by GordoCatCar
My rearview mirror is losing its electro chromatic coating. It has the distinctive split in coloration: top clear and bottom coated darker. Sometimes the fluid leaves a large oval shape on the mirror. The fluid is toxic and will eat the plastic on your shifter. Not a good thing. So far none of the fluid has leaked.
This is a common problem with early model Jaguar rearview mirrors, and a known defect in the product by the manufacturer Donnelly. This particular mirror, model #011530, was originally made in Ireland by Donnelly, which went out of business (not surprised) and was bought out by Magna, a large European automotive supplier.
Note the horizontal split between the upper and lower portions of the mirror.
Up to about March of 2008, the US Distributor in Holland MI, Magna Donnelly, was supplying replacements for free because of a recall. (The fluid is not toxic to humans, but it will damage your interior if it is not cleaned promptly) Replacements cost nearly $400 from Jaguar as an OEM item. So this what quite a deal indeed. The last free replacement occurred on or about October 2008. Since then, replacement mirrors are obtained through a vendor, Sybesma's Electronics, at a cost of $75.
Calling Magna Donnelly number (616-786-5115) will result in a recorded announcement saying if you are calling about a replacement interior mirror, you should contact Sybesma's Electronics. They are a contract vendor handling the mirror replacement on behalf of Magna Donnelly.
I emailed Sybesma's Electronics ; and received a reply from their rep, Stacy. she sent a PDF form with instructions to return along with pics of the mirror and its mounting point. They also require info regarding the connector, its color, the number of pins and the color of the mirror wires.
The firm re-manufacturers these units, and they will ask for your old mirror as a core. This one company receives 8 - 12 auto-dimming rearview mirrors for repair EVERY DAY. The vast majority have the same problem ours do, and most are from BMWs and a few other high-end cars.
The rebuilt mirror uses a gel pack instead of the toxic fluid so at least the potential damage issue is eliminated. The cost used to be $75, but around 2010 it went up to $95.
Once they receive your old mirror data, they re-manufacturer it, and upon receipt of payment, ships it back to you. You use the shipping box to return your old mirror. Most readers report down time as short as 72 hours, but rarely more than a week. If your car is a daily driver, you can purchase a cheap stick-on mirror to use while yours is being repaired.
Overhead Console
Remove the reading light/garage door opener overhead console from the header. There are three(3) prongs holding to the header bar. Get a screwdriver in the front first. Then you can work your fingertips around to both side and pull. It pulls straight down.
This pic illustrates the three (3) rectangular slots spaced in a triangular fashion. These correspond to the prongs on the overhead console. It pulls straight down. It may not be obvious that the three (3) points are not at the edges of the cover, but rather located in about an inch from the edge.
Remove the Connector
To access the power connector you should remove the black rectangular metal bracket attached by the two torqx screws. The connector is partially hidden behind the black bracket. Below is a picture of the yellow connector showing the input side. The mirror bundle had three (3) wires: Black, White and Grey. I think the extra wires are for the rain sensing option which was not installed on my vehicle.
Remove the Mirror
The mirror on my ’97 XK8 was attached to the windshield by a parallel slide joint using a plastic detent button. Bonded onto the inner windshield is a metal clip that accepts the pedestal mount. The mirror is removed by sliding it downward off the mount.
Note the yellow paper stick-on tab marks the stamped rise which fits in the detent and locks the mirror pedestal in place on the windshield mount. The tabs on either side are what hold the mirror to its windshield mount.
A metal clip is bonded to the windshield. Note the square detent. This is the seat where the protrusion (ID'd by the yellow button) of the mirror pedestal mount snaps into place.
Push the mirror bracket down towards the dash, PARALLEL to the windshield glass. Do not pry away from the glass. Do not twist the pedestal. I used a little WD-40 to lubricate the connection.
I used a length of soft wood and light rubber hammer to GENTLY tap the base of the mirror housing and it popped off w/o incident. Other owners said they just pulled the pedestal downward and it popped off. But remember keep all motion parallel with the inner face of the windshield.
Don't bother removing the plastic covers on the mirror pedestal. They should remain attached. They use flimsy plastic tabs which you will only have glue back on after you break them off.
Some other types of mirrors use a twist on/off cam lock. Others are attached by set screws on a post. It is important to first understand how the mirror is mounted on your car. In researching this project, countless owners reported cracking their windshields because they thought it was OK to "twist it a little bit"; or they they only just "pried it up gently". So if you are not comfortable with this type of task; take your car to a windshield shop and let them show you how to properly perform the mirror removal and install.
Your Choices to Replacing the Mirror
Note: You want to insure whatever replacement mirror you get uses a chromatic gel pack or film instead of the original toxic fluid. New old stock (NOS) from the original Donnelly inventory uses fluid. Be certain of your source.
1. Jaguar Dealer (same mirror) $380-400
2. Remanufactured by Sybesma's Electronics (same mirror) $95
3. Ebay $135 + shipping. - The same Magna Donnelly mirrors (#011530) are used on a number of cars including Acuras. However, these require their connectors be cut and replaced by the Jaguar connectors.
4. **** is a supplier of similar mirrors and they sell a GENTEX mirror which is almost an equivalent (model 36100). They are available from the manufacture and retail outlets. I do not know how they fit on an XK8 and did not do research on this option. I do know that owners have had success in upgrading their mirrors using **** to add extra functions like outside temp and a compass.
4. I could find no instance of anyone successfully completing an at home fix. Some readers did drill a hole in the unit and drain the fluid; however, the mirror is no without an auto dimming function.
Additional Notes: 4/2012
Member Iconoclast added the following disclaimer by Sybesma:
“...we must open the plastics in your mirror. In the rare instance your plastics break beyond repair, Sybesma's will make every effort to find a comparable replacement but no guarantees are made.
Also, be advised that we are unable to test the operations in the home link feature, auto head lamps and rain sensor, so your mirror may or may not have this as an operable function upon completion of the repair. If unit does break, $15 will be retained as a bench fee and the remaining refunded. (If you would like your mirror shipped back, an additional shipping/handling for charges will apply)”
Thanks a lot GordoCatCar, 10 years after, your excellent post continues to help many owners (including me).
I used Sybesma's electronics in Holland, MI for my mirror and I'm very happy about the repair they performed and the service.
Happy motoring.
Yann
Old Dec 31, 2017 | 07:06 AM
  #284
GordoCatCar's Avatar
Happy motoring.
Yann
Thanks Yann: Glad to hear your fix came out OK.
I still have the same XK8. Having the leather seats and trim recovered along w/ a new top and headliner as we speak. And yes, the mirror repair has held up all these years and it still works fine.
Old Dec 9, 2021 | 04:19 PM
  #285
wss25's Avatar
Mark
Were you able to find the fitting. Mine will not hold to the windshield. It is the standard rearview mirror and fitting for a 98 Jag XK8 mfg by Magna Donnelly.
Bill
Old Dec 11, 2021 | 07:09 AM
  #286
wss25's Avatar
Smile Donnelly mirror fitting spring replacement
My interior rearview mirror would not stay affixed to the windshield. The problem is someone twisted the mirror to damage the spring within the fitting. The Collection, the Jaguar dealer in Miami did not have the spring or know where to get it. I contacted Jim Shaub of Parts Soughtout 1, (shop@soughtout1.net) to help with what could be done. He reported back that Acura used the same Donnelly mirror as my 98 Jag XK8 and that Acura Factory Parts still has the Spring for sale. The part number is 76419-sz3-jo5. No guarantee it will work in all Donnelly mirrors installed in jaguars, but the part plus shipping is under $15, so it is worth a try. Mine is on order. I will report back if it solved the problem. As an aside, Jim Shaub is as knowledgeable a person out there on used Jaguar parts and I have found him most often the lowest price and prompt with delivery speed.
Old Aug 25, 2023 | 06:46 AM
  #287
GVR's Avatar
GVR
Default Sybesmas is now ATC Drivetrain
I was rolling down the road in the Jag 2001 xjr x308
it was hotter than Hades in Zurich, and I heard a loud CRACK sound. I thought a rock had hit my windscreen, but low and behold the dreaded rear view mirror bubble started forming on my rear view mirror, YES!I have heard all the stories about the ElectroChromatic goo leaking down out of the mirror once this happens, and on the console and eating the console basically. To avoid this I put a towel over the shifter console and found a replacement mirror at a junk yard in the USA for $25.00
I had them ship the mirror to:
https://sybesmas.com
which is now atcdrivetrain
https://atcdrivetrain.com/
Phone: (616) 392-6911
Toll Free: (800) 456-4265
Fax: (616) 392-9885
581 Ottawa Ave.
Suite 100
Holland, MI 49423, USA
They (sybesmas) acquired the contract to rebuild the mirrors years ago. They were just bought by actdrivetrain
Call them, ask about the Jaguar Mirror Rebuilding service.
The cost will be $125.00 The person to whom you should speak to is: Victoria Nowak She is very nice and EXTREMELY HELPFUL
victoria.nowak@atcdt.com as is her colleague who does the actual repairs.
Now getting the mirror on and off ( very easy to crack windscreen ) is very tricky so I am not very handy nor do I have the right tools so I opted to go with a Jaguar specialist near me.
Please file this away in case you require the mirror rebuild service
GVR
Old Jul 10, 2024 | 04:37 AM
  #288
someguywithajag's Avatar
I emailed her today. Unfortunately they have stopped offering the mirror repair service
Fax: (616) 392-9885
581 Ottawa Ave.
Suite 100
GVR
Old Jul 10, 2024 | 08:42 AM
  #289
waltwagner's Avatar
Anybody know another mirror repair service?
Old Jul 10, 2024 | 08:52 AM
  #290
motorcarman's Avatar
https://www.radar-mirror.com/
Old Jul 11, 2024 | 11:15 AM
  #291
Y2KJag's Avatar
As ​​​@motorcarman said, Radar Mirror is a good repair resource. In addition, eBay is a good resource if you need to just source a replacement. The "ball" joint at the back of my mirror was completely goofed up, too. Radar was kind enough to confirm that it was not reparable before I sent the mirror to them. I found a good used one off of eBay for about the same money as the repair would have cost. The trick was finding one with the same number of wires. The cars without rain-sensing wipers use fewer wires.
Old Jul 11, 2024 | 02:19 PM
  #292
abonano's Avatar
Radar Mirror just completed my mirror about a month ago. Great work. Got it out just in time before the material leaked out the mirror assembly.
Easy out, easy in - just take your time.
Old Jul 12, 2024 | 09:51 AM
  #293
waltwagner's Avatar
A used mirror would likely have the original electrochromatic fluid in it. So, even if it is not yet showing any rippling, etc., there might not be much time before failure and a necessary repair. But at least you would now have a unit that Radar could work on.
Old Aug 2, 2024 | 03:25 PM
  #294
davemellor's Avatar
Default XK8 Interior Mirror
First, many thanks to all for an incredibly useful site.
Sybesma seems to be in business no longer, any suggestions other than ebay?
Old Aug 2, 2024 | 04:05 PM
  #295
wss25's Avatar
Here is who I used. Good work. Took about three weeks roundturn.Thank You for your order!
Your order has been received. Your order details are shown below for your reference.
[img]file:///C:/Users/Admin/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/img]
If you placed an order for our Mirror Repair Service or Custom Integrated Mirror Display please include a copy of your Order Confirmation and ship your mirror and radar display (if applicable) to:
Scott Wheeler
Radar-Mirror.com
4319 Glenhurst Lane
Frisco, TX 75033
USA
Phone: 972-571-7427
Old Aug 3, 2024 | 08:39 AM
  #296
davemellor's Avatar
Thanks so much for the info on Radar-Mirror.com
Old Aug 4, 2024 | 11:12 AM
  #297
abonano's Avatar
Scott at Radar Mirror for sure. Great work!
Old Jul 26, 2025 | 09:09 AM
  #298
Vanya's Avatar
I recently bought my (3rd!) XK8 and some numpty had cut out and taped a "DIY" reflective sheet in the mirror aperture, giving everything a warped appearance and making things look dramatically closer than they were. Peeling it back I noticed that a PO had simply suffered the failure of the dimming function and wasn't bothered to address it properly. In my car, it would appear the liquid had either coagulated or leaked out previously. There was some black epoxy-like substance at the bottom center of the mirror frame, but perhaps this is standard on all cars.
Anyways, I am a cheap b*****d and of the 35+ vehicles I've owned over the years, never used the dimmer a single time. But I DO want a functioning rear view mirror. So here's the "pro bono" alternative that yields a functioning mirror, but without the auto-dimming feature.
1. Remove the reading light housing. As others have documented, on an XK8 Coupe this is held in with a push-fit using 3 clips. On my 99 the rearmost single clip comes off easily, just lightly pull down on it. The front two require more persuasion. I pulled straight down as close to them as I could - be sure not to lever the reading light housing against the windshield at the front edge. It took a little bit of courage - all fettling walks a fine line in force application - too little and you'll never get anywhere, too much and you've messed something up.
2. Remove the rear view mirror. Removing the little plastic cover near the top, the mirror slides off downwards, parallel to the windscreen. I didn't use a mallet, or any screwdrivers - I merely applied a moderate some light force while wiggling the fixing ever so slightly side to side. Your mileage may vary. I have a poverty-spec car so no rain sensor or other fancy stuff to consider.
3. Pry open the mirror housing. This part was not all that fun. I started at the top using various implements to crack it open and release the adhesive. Avoid screwdrivers and/or metal tools as the plastic frame mars and deforms easily - I opted for a variety of guitar picks of varying thickness, but it should be something that can be "twisted" to open the gap.
Top Tip: crack open the mirror housing at the top and sides, enough to reveal the two sheets of glass within. Mine was firmly epoxied at the bottom edge resulting in cracking/breakage had I pushed things too far.
4. Separate the glass. Remove the electrical connector on the outer layer of glass (visible from above). It's a simple press fit and can be put back later. After this, using some gentle persuasion, pry apart/separate the glass and withdraw the outermost clear glass.
5. Clean the surfaces. I used APC and got all the gunk off. Took some time.
6. Reassemble. Drop the glass but in from above, and glue the housing using an adhesive of your choice. I used regular plastic glue - not superglue or epoxy, should I have to open things up again. The trick part here is to accomplish this getting absolutely no dust or particles between the layers. I wasn't entirely successful, but the end result is still far better than what I began with.
Old May 9, 2026 | 08:30 PM
  #299
cdma's Avatar
Default Possible replacement?
Driving down the road, I hit a bump and my mirror will no longer stay up. It needed to be replaced anyway because it was already starting to fail.
So I asked ChatGPT about possible replacement mirrors. When I had this issue with my 1997 XJ6, I was able to install a Honda mirror and it worked great — and still does.
One of the suggestions it came back with was a Gentex mirror Link. What’s cool about it is that it also includes HomeLink for newer garage door openers.
I wanted to see if anyone here has tried this mirror on an XK8. From the pictures, it looks like it might fit pretty well.
Old Yesterday | 01:33 AM
  #300
I think you may be onto something here. The backside looks like it would fit... I have not bought it. The one on mine is still fine
montoya66
May 13, 2026 11:26 AM
dr.johnod
Feb 9, 2013 01:52 PM
Windycityx
Feb 2, 2012 02:13 PM
randyb
Sep 14, 2011 12:58 PM
epereira
Oct 22, 2010 12:44 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
