Bent lower radiator support/ front jacking point
Old Dec 21, 2024 | 01:09 AM
DaveAllen's Avatar
This thread has made me re-think how I lift the front of my XK8.
I used to remove the spoiler then lift with a large piece of wood.
I've had zero issues with this much quicker hockey puck method.
What do you think?
Lifting with spoiler in place
Hockey puck shaped to fit around spoiler
-Dave
Old Dec 21, 2024 | 02:53 AM
zray's Avatar
Originally Posted by DaveAllen
What do you think?
-Dave
I wouldn’t do it.
You are not spreading the impact enough.
Just an opinion of course.
But looking at the OP’s damage should speak volumes. Why take chance when a 2x4 is available.
Z
Old Dec 21, 2024 | 06:01 AM
Jon89's Avatar
Agreed. Spread the load with an 18-inch piece of 2x4 lumber. Much safer....
Old Dec 21, 2024 | 06:15 AM
STLTHMSTA's Avatar
With all due respect to all posters here, I would never use the cross member/brace to jack up the car. It just doesn't look strong enough to me and I wouldn't take the chance. Maybe only for a partial lift to get a little clearance but not the whole weight of the car, wether measured in lbs or k's.
Old Dec 21, 2024 | 08:33 AM
Jon89's Avatar
I think most of us jack up the crossmember just long enough to set up our jackstands on the sides of the car. Been doing it that way since early February 2012 (always using a 2x4 segment to spread the load) with no issues at all....
Old Dec 21, 2024 | 09:50 AM
scottatl's Avatar
Mine is bent also, that jacking point is a PoS. Mine has not broken the radiator but still, crazy a jacking point bends when jacked.....
Old Dec 21, 2024 | 10:30 AM
Hell-Cat's Avatar
I would seriously avoid using the lower radiator support as a jacking point, even when new it’s pretty thin steel. After a few years exposed to the elements and internal corrosion I wouldn’t trust it to support the car even momentarily.
If it bends, replacing that rad support is not trivial requiring nose cone removal and all the fun that goes along with that (e.g. removing headlamps). The support is made up of 2 panels (Main support crossmember FJE4059AA and a reinforcement panel FJB4059AA) both are now NLA. The lower support panel is spot welded to the front structural panel – the complete panel looks like this:
FJB4059AA-FJE4059AA-Traverse neuf JAGUAR XK8 - XKR Carrosserie ...A lot of work right there if you have time on your hands…
There is 1 complete panel available, I believe it’s at All4Jags (France) for 400 Euros, I’d buy it but USA shipping costs would probably give me a nosebleed and I already have the main panel – I’m searching for the reinforcing panel if anyone finds one.
So….put your car on low ramps and jack somewhere else. I use a floor jack and load spreader under the chassis rails which are made from much sturdier material.
Happy jacking !
Old Dec 22, 2024 | 11:12 AM
  #28
DaveAllen's Avatar
Thank you for the replies. I'll re-evaluate lifting the front when I next do some work on the car. I appreciate the feedback!
Cheers, Dave
Old Dec 23, 2024 | 09:28 PM
scottatl's Avatar
i am not sure where else you would lift from, i think if you use a 2x4 to spread the lift it should be fine. still, not well engineered
Old Dec 24, 2024 | 04:46 AM
  #30
RichardS's Avatar
The reinforced sill lifting points just after the front wheel are the recommended lifting points although you obviously need two jacks if you wish to lift both front wheels at the same time.
Richard
Old Dec 24, 2024 | 02:40 PM
  #31
cat_as_trophy's Avatar
+1 and Amen to that. The inner sill points are especially reinforced for jacking/lifting purposes. Both the owners manual and workshop manuals highlight this and specifically warn against lifting under any part of the cross beam that is the rad support. For those without access to a hoist, using a jack, then body stand, under one side then the other is a safe and effortless method of elevating the front of the car . . . and comes with the added advantage that you have unlimited access to everything under the front of the vehicle!
IMHO, this is not an example of poor design . . . but rather a failure to follow written procedures. I say this not to offend, but to highlight that procedures in manuals, TSBs and the like are given after careful thought to make life safer and easier (and to avoid what may be huge expense when something goes wrong!).
Cheers.
Old Dec 25, 2024 | 03:56 AM
  #32
RaceDiagnostics's Avatar
Cheers.
Have you read the X100 workshop manual, your comments are the opposite to what the manual indicates.
Old Dec 25, 2024 | 04:29 AM
  #33
michaelh's Avatar
I was just looking at this in the 3rd edition before I saw your reply.
So, it has persisted through to the 4.2L.
I wonder if Jaguar ever got any warranty claims resulting from the use of the 'Workshop Jack'? Of course, not going to happen anyway once the warranty expires (we did try to contact you about your extended warranty sir...)
This old curmudgeon thinks that, along with the centre-of-subframe for the rear, it's not the best idea.
Merry Christmas to all
Old Dec 25, 2024 | 09:17 AM
  #34
AbnMike's Avatar
Exactly.
0 issues raising mine there, even to a height of 20-24" to really get it off the ground to work under it. My low profile jack will raise to 24"
Old Dec 25, 2024 | 12:08 PM
  #35
michaelh's Avatar
À chacun son goût
Old Dec 25, 2024 | 01:51 PM
  #36
Yes, I have, and I take your point regarding the first warning in the procedures. My point relates to the second warning not to lift under the rad support cross beam, which was exactly the error highlighted by the OP. I regard the first (jacking one wheel) as by far the lesser of two evils. Without it, we could never change a flat tyre beside the road! OTOH, I have seen not only DIY but also trained mechanics confuse the rad support beam with the main front cross-member, with dire results, just as the OP has reported.
Of the two warnings, my years of experience point to the advice I offered . . . mind you, I have for many years enjoyed the benefit of a 4ton hoist, which eliminates the up-and-down using crawler that my old back no longer enjoys. That said, I applaud your highlighting the issues by way of the manual diagrams . . . anything that emphasizes what is and what is not a jacking point, is commendable . . . hence, my thanks.
Cheers,
Old Dec 26, 2024 | 11:45 AM
  #37
bladerunner919's Avatar
But there isn't a warning NOT to lift under the rad support. The manual specifically says you should do that?
Lagonia
Mark V - X 420G
Aug 1, 2022 09:05 PM
stu46h
Nov 22, 2020 08:48 AM
chrisc923
May 21, 2014 07:04 PM
Time-Pilot
Mar 14, 2014 05:15 PM
Qgregg
May 1, 2012 04:43 PM
