bonnet earth lead
Old Jul 16, 2014 | 09:57 AM
bobg's Avatar
Default bonnet earth lead
does anyone know what the purpose of the bonnet earth lead part #LMB3741AA and if i have a broken one should i get it replaced? this is on an xk8
Old Jul 16, 2014 | 10:12 AM
The Coupe's Avatar
You absolutely must get it replaced.
Earth leads are the grounding paths from your electronics back to the battery. When they are broken, loose or corroded, bad things start to happen.
Old Jul 16, 2014 | 10:47 AM
Johnken's Avatar
bobg, often grounds like this also prevent RFI (radio freq. interference) from electronics in the engine compartment. John
Old Jul 17, 2014 | 03:54 AM
ArtyH's Avatar
I am a bit confused by this post as I cannot find this part on my car. Is it for a specific year or for all 8's. Any pics would be much appreciated.
I thought the bonnet would be earthed through the hinged mechanism directly to the frame. Any comments welcomed.
Cheers, Arty
Old Jul 17, 2014 | 08:46 AM
graham11's Avatar
lift your bonnet and its the braided lead about 12inch long at the front and just off center of the front your bonnet,well it is on mine.
Old Nov 12, 2017 | 08:30 AM
jaguar51's Avatar
Default Ground Lead Bonnet
Ground Lead Bonnet Part# LMB3741AA Over $54.00
Try an auto parts store to find a knock off replacement for $5.00. Make sure it's a flexible thick gauge braided wire with connectors if possible. Bonnet struts must be taken off to get at left frame 13mm nut holding on the ground lead, same for the bolt connection to the bonnet, it's an easy install with the bonnet struts disconnected and the bonnet leaning forward and braced with a 36 inch board so not to fall back on you while your working, clean all connection surfaces and bolts with wire brush before reconnecting new ground lead.
Old Nov 12, 2017 | 01:08 PM
avern1's Avatar
Skip the board and insert bolts in the bonnet service position holes. It's much safer and doesn't put a strain on the bonnet.
Old Nov 12, 2017 | 01:20 PM
jaguar51's Avatar
What do you mean by skip the "board", is that the metal plate with the bolt?
Old Nov 13, 2017 | 03:50 PM
phanc60844's Avatar
There are no electrical items on the bonnet so this can only be something to do with RFI and to be fair, probably does little if any good and chances are you could leave it as is.
Old Nov 14, 2017 | 08:34 AM
JagNoir's Avatar
Posted by jaguar51 (4 posts up):
That board.
Old Nov 14, 2017 | 09:48 AM
avern1's Avatar
With the bonnet struts disconnected and the bonnet raised vertically will find that the 2 holes on each hinge line up and a bolt slid in the holes is called "bonnet service position"
Old Nov 14, 2017 | 11:01 AM
jaguar51's Avatar
Smile
Ah, thank you, I now wonder what diameter and proper lenght (mm) the bolts needs to be?
Old Nov 14, 2017 | 11:07 AM
Look here https://www.jaguarforums.com/forum/x...osition-84402/
M12 x 25mm allegedly.
jagent
Jun 5, 2022 02:18 PM
Tahoe Dave
Sep 28, 2015 07:42 AM
thedugger1
Sep 26, 2015 10:27 PM
vacolorito
Sep 25, 2015 09:29 AM
