Both Front Tyres wearing on Inner Edges only!
Old Sep 15, 2014 | 02:32 PM
rp2427's Avatar
Default Both Front Tyres wearing on Inner Edges only!
Fronts : 245/45 r18 (Barums Xl) understand made by Continental !
Rears : 255/45 r 18 (Barums Xl)
Have noticed over the last few months that both front tyres have been wearing just on the inner edges only ?
Front main tyre treads at 6mm with both edges hovering around 3mm !
Rear tyre tread even at 5mm !
Have had the tracking checked and adjusted about a year ago, and again recently, but not found out of alignment ! All tyres have been balanced recently too! No steering problems nor any shudder!
Anyone experienced or experiencing the same problems ?
Any ideas as to why I am encountering this uneven tread wear appreciated..
Ps..Am really happy with the tyres (Barum) they grip and hold the road well both in dry and wet conditions..Previous tyres were Continental Sports!
2001 Xk8 4.0 (UK) Rob.
Old Sep 15, 2014 | 02:35 PM
DaveInVA's Avatar
I had the same problem. It turned out the toe-in was out of spec when I had the alignment done. The camber was good but the castor was also off but that won't effect tire wear. If both tires are wearing the same way its usually excessive toe.
Dave
Old Sep 15, 2014 | 03:04 PM
worrasf's Avatar
I also had this but just on the front left - the tracking was out but the tyre chap took ages getting the exact setup data for the laser tracking from jaguar so I'm suspecting it wasn't done right before
Old Sep 15, 2014 | 03:23 PM
Don-T's Avatar
Betcha that the toe-in was set with the suspension/wheels relaxed. At our cars age, unless all the soft parts are newly replaced, the wheels will spread a bit when driven. The toe needs to be set with some pressure applied to spread the front edges of the wheels.
Old Sep 15, 2014 | 03:44 PM
weisberg's Avatar
both of my fronts had the same thing, the front left was worse by far
It had a four wheel alignment with all new tires two years ago, and another four wheel alignment a year after. And it still happened.
Now onto my second set of fronts after just 10,000 miles.
same michelin type on a Porsche Boxster for 30,000 miles and 5 years so its a Jag XK8/R thing....
Old Sep 15, 2014 | 04:33 PM
RaceDiagnostics's Avatar
I also just noticed that I have bad inner edge tyre wear, new tyres and full alignment only 4.5k miles ago. I'm really pissed of with myself that I didnt keep a better eye on them.
Anyway my front lower wishbone rear bushes showed up to be colapsing at my MOT a few weeks ago. The car is in getting painted right now but since the paint shop is next ddor to the alignment shop I will get it retested when I pick it up later this week before and then after changing the bushes.
Old Sep 15, 2014 | 08:21 PM
tberg's Avatar
This happens because unless you have replaced the shock bushings, and your car sits low, you can not get an alignment within specs because there isn't enough adjustment to allow it. The same thing has happened to me on three sets of tires. Now that I am having all of the undercarriage work done as a result of the object I ran over, I am going ahead and ordering the mounts so that I can try and align properly. The springs may have sagged too much over 150,000 miles for the shock mounts to make up the difference, but we'll start there.
Old Sep 15, 2014 | 11:29 PM
rp2427's Avatar
Thanks, thought It may have been just on my Xk8 !
Does anyone know the correct Jaguar settings for the wheel alignment ?
I'll get them to adjust to that spec and monitor to see what happens.
Old Sep 16, 2014 | 03:14 AM
If you go to quikfit they have the latest hunter machines with the setting built in, just watch them like a hawk to make sure they select the correct vehicle, model and year.
As you can see from the above posts there could be a number of reasons for the wear.
Old Sep 16, 2014 | 06:53 AM
rp2427's Avatar
Hi, just got a reply from another Website which may be of interest and shed some light on the situation!
"Very common , your lower ball joints need replacing. Won't be an MOT failure as they don't move much but on the road they allow the suspension to spread giving you inner tyre wear. It won't show up on alignment either. On an XK get the whole lot powerflexed
Don't take it to a main dealer who will want £300+ to replace the arms and the ball joint , you can buy just the ball joint and indi's will fit."
Will look into trying this option out rather than new tyres every 10,000 miles!
Thanks everyone.
Old Sep 16, 2014 | 07:11 AM
Jon89's Avatar
Good information all around. It proves that we all need to pay consistent attention to how all of our tires are wearing even when we believe that our recent four-wheel alignments will protect us from abnormal wear. A simple tread-depth gauge is a must-have tool. I've had mine for 20+ years and it has helped me to discover alignment or suspension issues shortly after they began and saved me considerable money in the process....
Don't rely on just eyeballing your tires. Get a tread-depth gauge and use it at least monthly. Your eyes can get fooled. Your tread-depth gauge cannot....
Old Sep 16, 2014 | 08:57 AM
P700Dee's Avatar
Thanks everyone.
Glad you found my post useful.
I suggest you try Penge Jaguar spares who did myine
Old Sep 21, 2014 | 12:12 PM
wsimoncm's Avatar
ditto same thing.
My project the other weekend was to replace the Shocks and upper shock mounts, when I took the wheels off, I saw the inside edges on both sides totally bald.
an extra $600 with wheel alignment I had not banked on.
will take JON89 's advice and get a tire gauge, in case the guys at Firestone didn't do a good job.
RP2427 - the Ball joint bushing is new to me, but possible - does anyone else have any additonal info?
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
GordoCatCar
Jan 2, 2017 01:10 PM
fingers
Sep 11, 2015 12:21 PM
fingers
Sep 8, 2015 03:54 PM
