Clunking front right wheel?
Old May 3, 2012 | 09:34 AM
kiphome's Avatar
Default Clunking front right wheel?
Ok, clunking may not be the most technical term! However, there is a definite clunk from the right front wheel whenever I go over a speed bump or a pothole or whatever.
I have an 02 xkr 100, if that makes a difference to anyones opinion of the situation.
I am wondering what it could be and what I can expect for a repair bill.
Thanks in advance for your help!
Kip
Old May 3, 2012 | 09:38 AM
oldmots's Avatar
Saying that something is loose may not be specific enough, but I would start by looking at the sway bar bushings. There are a bunch of bushings and brake parts there that can clunk, just eliminate them one by one.
Old May 3, 2012 | 10:57 AM
There's a lot of bushes can wear in the front suspension. This drawing may help you with where to check:
JTIS - 2002 Front Suspension.pdf
In league table order for failure are
item 3: upper wishbone bushes
item 8: upper balljoint
item 5: lower wishbone bushes
item 7: lower balljoint
item 2: shock absorber - both ends
item 6: stabiliser bar
It could also be coming from the front crossmember or steering or even a pebble stuck in the tyre tread.
Old May 3, 2012 | 11:24 AM
kiphome's Avatar
My understanding is that the XKR100 has a slightly different suspension set up than the regular XKR, however, i could be incorrect about that. Something to do with an advanced stability control system or something.
My mechanic indicated that it was "housed" or sealed unit and he wouldn't know what was wrong until he got inside it.
Does that sound correct or plausible? I am sure it is plausible, he seems very knowledgeable and reputable although on my last visit, a $400 60,000 mile tune up turned into a $2000 rear brake job so I am a bit reticent!
thanks,
Kip
Old May 3, 2012 | 12:55 PM
See the final section of the PDF in Post 3 above.
This outlines the differences in the suspension on vehicles fitted with the Enhanced Handling Pack.
Old May 4, 2012 | 04:43 PM
oldjaglover's Avatar
And the sway bar end links are probably the first to go, easiest to replace, and cheapest of all the "wear out" components.
Park the car on level ground, with it in park, but don't set the e-brake. Wheels straight, push hard horizontally on the top of your tire (might as well do both sides), and see if you get a clunking or clanking sound. Use your foot and give it a good shove. If it clunks/clanks, start with the sway bar end links.
Old Jan 14, 2013 | 12:37 PM
sweatyfox's Avatar
Hi Kiphome,
Did you ever find out what the clunking/knocking was?
I had exactly the same problem on mine one day, but the cause was a bit frightening.
Wasnt the usual wornout balljonts or bushes, but a snapped lower wishbone!
I've never really pushed the car, always avoided potholes and taken the less bumpy roads. Was just wondering if anyone else experience this?
Old Jan 14, 2013 | 12:46 PM
sstilley's Avatar
Wow Now I want to look at mine.
Old Jan 14, 2013 | 12:54 PM
Originally Posted by sweatyfox
................. Was just wondering if anyone else experience this?
SNAP!
This is the LH on a 2001 XK8.
Old Jan 14, 2013 | 05:44 PM
NikasilNik's Avatar
Hi Kiphome,
Hi Sweatyfox ,
I've know of several XK's doing this , it's caused by seized bushes , the wishbone can't move because the bush has seized so it flexes and cracks the cast wishbone instead , can cause a nasty accident !!!
........by the way , that's an upper wishbone , lowers are much , much harder to crack and break
All the best
NikasilNik
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
