Convertible top drip
Old Mar 29, 2025 | 11:47 AM
Brian G's Avatar
Default Convertible top drip
Apparently this is a unusual issue for the X100 convertible but I have a leak. Actually, its a slow drip, (1 hz), but it's enough to wet the gunwale carpet beneath the drip and it is present on both sides. The drip emanates from the top edge of the door glass in the area of the first fold joint of the top frame. Examination of the seals reveals that the seals are in excellent condition overall with no apparent damage or degeneration. The area where the seals join, in the area of the leak appear normal and in good condition as well.
The window to seal contact appears firm.
This leak occurs with any consistent rain and does not require a deluge.
I must be missing something?
Old Mar 29, 2025 | 12:27 PM
Jon89's Avatar
I would condition the rubber seals with SylGlide or a similar product. If you cannot spot the leak, that may be all you need to do in order to stop it.....
Old Mar 29, 2025 | 03:46 PM
robak's Avatar
hey. as my english isnt tht good. can you attach a picture of the location you suggest the water coming in?
i had multiple leaks on mine and i solved them all xD
Old Mar 29, 2025 | 05:57 PM
Brian G's Avatar
The drip comes from just forward of this joint.
Old Mar 29, 2025 | 06:58 PM
robak's Avatar
hmm okay. that one is new to me.
is there any cut you can locate?
Old Mar 29, 2025 | 07:13 PM
Brian G's Avatar
As noted above, the seals appear flawless.
Old Mar 29, 2025 | 07:51 PM
JACKP's Avatar
Is the window going all the way up?
Jack
Old Mar 29, 2025 | 09:39 PM
Brian G's Avatar
Jack
The reset process appears to work as designed. The seal seems firm, as demonstrated by a paper-pull test.
Old Mar 31, 2025 | 09:56 PM
Brian G's Avatar
I may have discovered the reason for the leaks. There is a narrow lip component to the outboard aspect of the rubber roof-to-window seal. This narrow lip appears designed to cover and seal the outer aspect of the metal roof frame. On mine, this lip was partially folded under the frame causing a buckle in that lip that might have compromised the water seal.
I have unfolded this rubber lip and touched it with a bit of heatgun after which it appears to be laying flat again.
We shall see how it goes next rain... 🤪
Old Apr 1, 2025 | 05:40 PM
Firechief's Avatar
Good luck and please let us know the results !
Old Apr 12, 2025 | 11:18 AM
Brian G's Avatar
The "clean and treat" process has done the trick. I washed down all of the rubber seals on the convertible roof frame and on the door using a solution of water, dish soap (detergent) and isopropyl alcohol. I was amazed at the amount of "black stuff" that was lifted!
I then treated the seals with a "rubber seal conditioner" made by "3 In One".
No more leaks.
Old Apr 12, 2025 | 01:02 PM
Jon89's Avatar
Well done....
XxSlowpokexX
Sep 12, 2024 11:02 PM
ebrisec
Sep 23, 2018 03:05 PM
Robert Galask
Dec 26, 2016 05:23 PM
Nukeracer
Feb 1, 2012 06:36 AM
