Coolant leak & pressure test question
Old Mar 18, 2016 | 03:10 PM
DougBoost's Avatar
Default Coolant leak & pressure test question
We're losing ever so slight amount of coolant (top off about every 2 weeks) and I suspect the thermostat housing and/or water pump. Our car is a 2006 XK8 with 65,000 miles and I'd appreciate the collective wisdom of the good folks on this forum since am sure this is common, especially with that plastic housing (I recall hearing of an aluminum upgrade?)
I have a pressure tester and the right radiator cap adapter but it won't pressurize. The air pressure appears to be going immediately out the overflow tube, which the stock cap appears to close off. Is there a good way to block this off for the test? I tried clamping the hose with vice grips but it leaked...it seems blocking that small orifice from the inside with something would be smarter.
It appears the water pump weep hole in these cars is on the top instead of the bottom, and I do see traces of orange coolant around that hole and on top of that area. See attached picture.
I also see the bottom of the reservoir housing itself is leaking per attached pictures. This part was replaced by our Jaguar dealer a couple years ago under warranty so not sure if it cracked again or is perhaps a hose clamp problem.
Thanks,
Doug
Thermostat housing, 2006 XK8
Bottom of coolant reservoir, left side
Bottom of coolant reservoir, right side
Old Mar 18, 2016 | 04:06 PM
RJ237's Avatar
Actually, you don't have the right adapter. The cap has two seats. The first allows the coolant to go to the overflow tank as the system pressurizes, then allows the coolant to return when the engine cools. The second prevents coolant escaping from the tank.
Your adapter is sealing the top seal, but should be sealing on the lower shoulder.
Old Mar 18, 2016 | 04:17 PM
DougBoost's Avatar
Thanks, you were right. Was the green one in my kit.
Old Mar 18, 2016 | 04:38 PM
DougBoost's Avatar
These coolant pressure test kits are a must have tool. It's definitely leaking from behind the water pump pulley (and only there) so looks like water pump time. Also probably explains the line of coolant splashed on the right cylinder head.
I know it's good preventative maintenance to also replace the thermostat and hoses, but what else? Is there an aluminum housing "bridge" I should also get? Perhaps a full kit from an aftermarket supplier?
Thanks again,
Doug
Old Mar 18, 2016 | 06:32 PM
test point's Avatar
The later engines were significantly upgraded from our earlier versions ('02) in that there is no plastic thermostat housing to fail and no plastic cross over pipe to rot. While not aware of aftermarket upgrades I would suggest that 9+ year old hoses could stand to be replaced with the other work. After 'renting' pressure test equipment from Advance, AutoZone and O'Rilley I can certify that none contain a direct adapter for our cars. They all have an universal expanding adapter that fits the reservoir and excludes the overflow chamber.
Old Mar 18, 2016 | 07:04 PM
RJ237's Avatar
The one I bought at Harbor Freight does have an adapter that fits. I was surprised.
Old Mar 19, 2016 | 08:59 AM
DougBoost's Avatar
The HF kit is the one I bought after reading about it ion this forum. This was after going to the parts store to see their useless tester that would only work on my 1973 Camaro. With the many adapters included, and fact I have 7 cars and counting, it's a great investment.
Old Mar 19, 2016 | 09:30 AM
DougBoost's Avatar
Any experience here on best brand of water pump? On RA I see GMB, Airtex, ACDelco, Cardone Select, and Beck/Arnley.
And the thermostat they show just one option, a 192 degree with housing. The housing appears plastic, should I avoid this for my 2006?
Thanks again!
Doug
Old Mar 19, 2016 | 04:05 PM
stevepaa's Avatar
HF one looks good. I bought mityvac years ago.
Old Mar 19, 2016 | 05:05 PM
test point's Avatar
For cars beyond '02 there is no choice beyond plastic . . . that I am aware of.
Old Mar 19, 2016 | 05:28 PM
NBCat's Avatar
On the 4.2 Litre units, it is a good idea to replace the plastic thermostat housing and outlet each time the coolant is changed. The assembly includes a new thermostat.
Old Mar 19, 2016 | 07:24 PM
brgjag's Avatar
My take on the plastic tstat housing is that is on mine (03) it last 98k miles, another new one will last beyond the time I have the car. i used the AC Delco replacement WP. It is just like the OEM, metal gasket, o-ring.
This is what I put on mine. same as what I pulled off.
Engine Water Pump ACDelco Pro 252 800 | eBay
Old Mar 20, 2016 | 08:15 PM
DougBoost's Avatar
Thanks, the AC Delco looked best to me, too and was already in my cart
Old Mar 29, 2016 | 09:25 AM
DougBoost's Avatar
Default Update: new vs. old water pump pix
When I started unbolting the old water pump I had a sick feeling I'd bought the wrong pump since there were 2 extra bolts on the old one and they looked quite a bit different. But turned out the old pump was a 2 piece unit while the AC Delco was one cast piece.
As you can see by the pictures the old one also had a plastic impeller (yuk!) vs. the cast iron one in the Delco. So a nice upgrade.
mhamilton
19
Apr 5, 2024 04:06 AM
Computer Budda
Mar 22, 2016 02:51 PM
RobinGa
Mar 15, 2016 11:22 PM
Mark1975
Mar 7, 2016 01:41 PM
simong1
Feb 25, 2016 07:33 AM
