Coolant Pressure Testing
Old Jun 23, 2014 | 09:45 AM
YYC guy's Avatar
Default Coolant Pressure Testing
Hi All,
I have a very small coolant leak but cannot find where it is coming from, I borrowed a pressure tester and purchased the correct adaptor but the system will not pressure up no matter how much I pump. I tried it on another vehicle and it works fine. Am I Missing something here?
Regards,
Karl
Old Jun 23, 2014 | 10:19 AM
RJ237's Avatar
I would question the 'correct adapter' first. It has to seal the overflow.
Old Jun 23, 2014 | 10:27 AM
Fulton's Avatar
I bought this one from Harbor Freight, it's the green adapter. You must have the wrong adapter for yours.
Old Jun 23, 2014 | 11:54 AM
Brutal's Avatar
Just crimp off the overflow with vise grips etc... You dont need another tool
Old Jun 23, 2014 | 12:47 PM
blindside's Avatar
Jeff - Just to confirm - that green adapter works with the XK8? I only ask because the owner's manual they have online for that one says the green adapter is for GM... if it works for the xk8 then I will definitely pick it up
Old Jun 23, 2014 | 06:34 PM
test point's Avatar
I have 'rented' pressure testers from a couple AP stores and neither had one to fit the Jaguar. Neither sealed the system from the overflow orifice in the neck of the pressure cap. Ended up using the 'universal' on both and that worked.
Old Jun 23, 2014 | 07:43 PM
Fulton's Avatar
I went out to the garage to check, yes the green one. I see the confusion, the manual says #17 Green = GM. However the green one is marked #21 which isn't even in the manual. Good thing I don't read manuals, I write them.
Attached Thumbnails Coolant Pressure Testing-img_00000194.jpg   Coolant Pressure Testing-img_00000195.jpg
Old Jun 23, 2014 | 07:50 PM
2000CAXK8's Avatar
ugh i need to do this. My car goes through more bottles of water than me.
toronadomike
Jan 22, 2026 10:13 PM
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
willtoliv
Oct 2, 2015 12:18 PM
