Correct identification for coil issue
Old May 9, 2026 | 10:50 AM
mjmindling's Avatar
Default Correct identification for coil issue
Good Morning! This is Martin in Menifee CA; my car us a 2001 XK8 convertible. Receiving code warnings and getting rough engine problems.
Using an ActronII code reader, showing code of PO354, which is indicated as cylinder 4. I'm concernined with pulling the wrong coil
This issue has come up on the forum several times, but I'm not sure about the correct location of the bad coil. I would appreciate a clear identification of the coil such as left bank (drivers side), number four cylinder next to the fire wall? Thanks for you patience, I know that someone has a perfect description but at 78 I'm worried about
making a obvious mistake. Not as sharp as earlier in life.
Thanks to All,
Martin
Old May 9, 2026 | 02:35 PM
giandanielxk8's Avatar
In these cars, very often when one coil is bad and causing codes, the others are not far from also failing.
Save yourself the headache and do all 8 coils. Get the Denso coils.
Old May 9, 2026 | 03:51 PM
michaelh's Avatar
Hi Martin,
#4 is the rearmost cylinder on the RHS.
Check this post:
https://www.jaguarforums.com/forum/x...3/#post2909999
Old May 9, 2026 | 04:24 PM
Y2KJag's Avatar
Thanks to All,
Martin
The way I am able to remember is that the 4.0 engines use Ford's numbering system. 1-4 are front to rear, right side. 5-8 are front to rear, left side.
Old May 9, 2026 | 05:14 PM
mjmindling's Avatar
Many thanks to all. Sic Transit Gloriam!
Old May 11, 2026 | 07:51 AM
JagV8's Avatar
The newer cars use SAE / ISO cylinder numbering which is also used by OBD II.
graham11
Jul 1, 2024 06:14 PM
Jandreu
Jul 15, 2016 04:06 AM
millenia
Aug 28, 2014 02:21 PM
genec
Jul 5, 2014 07:25 PM
