Cost to replace lower ball joint?
Old Dec 14, 2013 | 12:12 PM
Windycityx's Avatar
Default Cost to replace lower ball joint?
What would the going rate at an indy shop be to replace the front passenger lower ball joint? And what tools and how many hours is about the average? Thanks!
Old Dec 14, 2013 | 12:17 PM
XKRacer's Avatar
No special tools..... $150 including parts.... Takes about an hour
Old Dec 14, 2013 | 02:09 PM
Windycityx's Avatar
Are there any videos on how to do this?
Old Dec 14, 2013 | 03:28 PM
Windycityx's Avatar
My mechanic is having an issue with how to separate the lower ball joint from the knuckle and then how to separate it from the lower control arm?
Old Dec 14, 2013 | 04:19 PM
motorcarman's Avatar
Jaguar sells the front rear lower control arm as an assy. (with the ball joint).
The problem with the lower arm is the outer section is cut at an angle and holding it while the ball joint is pressed in might be difficult.
I thought about making an angle jig/plate with a locating pin to hold it flat in the press. A shallow hole in the arm would keep it from sliding.
The ball joint is a standard taper fit so the regular removal procedure from the vertical link is required ('pickle fork', a BFH or an air hammer).
I have replaced XJ8 lower ball joints but not XK8.
bob gauff
Old Dec 14, 2013 | 04:46 PM
Windycityx's Avatar
I ordered and have a ball joint, which was 2 for $48, what other parts will I need to just replace the ball joint if possible?
Old Dec 15, 2013 | 07:38 PM
RaceDiagnostics's Avatar
This can be a pig of a job, my first ball joint splitter broke trying to split it.
Once you do have it free and get the old one out of the control arm then you do need a special tool or jig to get the new one in.
There is no way this job could have been done in an hour on my car.
Remove the old one like this after cutting off the flange.
Getting the new one in is tricky as you need to make a tool.
Old Dec 16, 2013 | 05:59 AM
XKRacer's Avatar
When I said no special tools I must admit I took my press for granted, but I do not press the new ball joint in, I simply use a large deep reach socket over the top, hold the arm in a vice and tap it in with a hammer, I have done dozens like this with no probs at all.....
In all the years I have been doing this I have never fitted a standard bush, always been poly, which is very much easier than the OE of course the downside is you will have to do both sides
Old Dec 17, 2013 | 06:43 AM
Thanks for the tip, I will try that if I ever need to do it again on this car.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
