Draining the entire tank through fuel filter connection
Old Apr 4, 2020 | 02:25 PM
crbass's Avatar
Default Draining the entire tank through fuel filter connection
So, I'm 6 14 gallons of petrol/gas into a fuel filter replacement. I expected a small amount of fuel, but I started collecting it when it was spilling from the driveway into the street and my lawn. Four Six Fourteen gallons collected, I expect the next 10 8 0 gallons will come out too. (note: no more gallons left to come out)
This seems like an inefficient way to transfer fuel between my vehicles, any thoughts on stopping the constant but relatively slow deluge? At this point, it will stop either
1. because of something I do short of dropping the tank, or
2. it runs out of fuel since I have a plethora of cars to transfer it too.
I assume siphoning from the fill is not an option because of some anti-siphon feature?
Problem solved, out of gas.
Old Apr 4, 2020 | 02:30 PM
did you not depressurize the fuel system before removing the filter?? Should only spill what's in the filter - not much more
Old Apr 4, 2020 | 02:51 PM
crbass's Avatar
Tis depressurized at the rail. Has to be siphoning from the tank at this point. Unclear how that is working.
Old Apr 4, 2020 | 03:36 PM
Johnken's Avatar
Gas caps off right? Yes obvious I know but I almost suggested letting the fuel pump do the work .
Old Apr 4, 2020 | 03:58 PM
crbass's Avatar
Yes, thanks for this thought, as the gallons kept leaking, gas everywhere, many many thoughts came to mind....
Immediate problem solved, no more gas. I guess I'll dig into the fuel system some time soon. Probably not with a fulliish tank.
Old Apr 4, 2020 | 04:22 PM
motorcarman's Avatar
I've had just a few cars leak and NOT stop during fuel filter change. I imagine the check valve in the pump is faulty?
Old Apr 4, 2020 | 05:09 PM
crbass's Avatar
Was wondering. Does this have any other implications (other than every leak siphoning out the whole tank), or should I just make sure I'm low next time?
Old Apr 4, 2020 | 06:03 PM
cjd777's Avatar
Dale, did not have that trouble changing filter on my 2000, but when changing the fuel pump a couple of months ago. I drained it from the fill hole.
Used a 1/4 inch inside clear plastic hose attached to the hand pump I got at HF. Took a while and it was only 6 gallons, so a electric pump would be better.
The length installed from the mouth of the fill hole was 44 inches and it got all but a pint or less out. The two pipes set up from the bottom of the tank by about 1 and 1/2 inches, so a gallon could still be in there.
Old Apr 4, 2020 | 09:27 PM
crbass's Avatar
Appreciate it, I suppose this is a good trick for next next time. Run it down, see what I can take out with this approach, change the filter. Unless I need to replace the fuel pump for some reason. I have a pneumatic pump, which seems good for this. I knew I installed an air line in my garage for some reason.
Old Apr 5, 2020 | 05:52 AM
cjd777's Avatar
Dale, If you need to rep[lace the fuel pump, just say when and Jon and I can make a road trip, even if we just bring support and a couple of tools.
Wayne
Old Apr 5, 2020 | 06:50 AM
Jon89's Avatar
Yep; we can definitely help. We just went through a fuel pump replacement on Wayne's 2000 XK8 back in January. Wayne now has all the tools needed (especially that skinny 22-inch-long flat-blade screwdriver with the custom-ground tip used to release the fuel lines underneath the car) and we also know exactly which curse words to shout at each stage of the job...
Old Apr 5, 2020 | 10:19 AM
crbass's Avatar
Wayne
Really appreciate it.
Old Apr 12, 2020 | 06:58 AM
Shoreguy's Avatar
Veteran: Air Force
This is starting to sound like a Carolina's meet and wrench. Might be a great idea would love to meet all Y'all.
Old Apr 12, 2020 | 11:48 AM
Jon89's Avatar
Shoreguy,
After the pandemic is long gone, we should arrange a group meeting at Wayne's shop in Spencer. We could all then head out for a great BBQ lunch at one of the local joints. Perhaps on a gorgeous North Carolina autumn day come October....
RobHathaway
Jan 3, 2017 04:33 AM
1964Daimler
Aug 3, 2016 08:32 AM
funcars
Dec 16, 2015 06:15 PM
downsouth
Aug 27, 2014 08:28 PM
RizwanSharp
17
Nov 15, 2010 09:40 AM
