Dumb question about shocks
Old Dec 2, 2010 | 07:06 AM
chazaroo's Avatar
Default Dumb question about shocks
I'm going to replace my shocks and see them with and without Adaptive Control Dampening. What the heck is that and how do I find out if I have it?
Old Dec 2, 2010 | 09:41 AM
uropnm6's Avatar
If you open the hood you will see a two wire connection attached to the top of each shock if you have the computer adaptive suspension.
Old Dec 2, 2010 | 01:43 PM
H20boy's Avatar
a regular xk8 should not have the CATS as standard
Old Dec 2, 2010 | 02:46 PM
chazaroo's Avatar
Thanks for the info! Whew, no wire. That means the shocks are a lot more reasonably priced
Old Dec 2, 2010 | 04:15 PM
H20boy's Avatar
bilstein (non-jag dealer source) +100 each, very reasonable.
Old Dec 3, 2010 | 06:49 AM
chazaroo's Avatar
MAtt,
Thanks!. Found 'em!
Old Dec 7, 2010 | 02:00 PM
chazaroo's Avatar
Got new Bilstein shocks installed and just got the car back. Labor $550. Not sure if that's good or not. Apparently it isn't a real easy job. Major ride difference. The old shocks were obviously ready to be replaced.
Old Dec 7, 2010 | 09:06 PM
H20boy's Avatar
I would expect 1.5-2 hours per shock, although the jaguar part's list shows 1.2 hours for R&R each. I am now looking forward to my new shocks and a few bushings down there.
Old Dec 7, 2010 | 10:16 PM
Reverend Sam's Avatar
Is there a good way to tell if you need new shocks? The car doesn't keep bouncing when I push up and down on a fender. I'm going to be doing new lower suspension bushings soon, and that seems like a good a time as any to replace the shocks, but I don't want to spend the money on the shocks unless I need to.
Old Dec 8, 2010 | 02:08 AM
XKRacer's Avatar
You can spend that long just removing the top wishbone fulcrum bolt I allow 3 hours a side then if everything comes apart easy then the customer pays less, it can be a real PITA sometimes
Old Dec 8, 2010 | 07:23 AM
chazaroo's Avatar
Sounds like the labor price I got was fair based on the hours needed to do the job. As far as Reverend Sam's question, I just thought the ride was getting a little soft and with 75k on the odometer, I figured it was about time. The ride difference with the new Bilsteins convinced me I was right.
Old Dec 8, 2010 | 09:14 AM
H20boy's Avatar
...and I'm at 116k on the originals...it won't hurt since I've got my lower arms off during the project.
Like you Sam, my front doesn't 'bounce' either when giving the push-down test in the garage. What convinced me take the shocks into consideration...I had my car up to inspect the bushings and sway bar and track down that power steering fluid leak (going to be fixed next week!) and when I put the floor jack under the front bumper to reach the center of the cross member, it rubbed the lower valence on travel. After 30 minutes up in the air, I brought the car down and the jack had an inch of clearance. Scratchin my head, I thought that the longer the car sits on those springs and shocks, the car drops lower. If for whatever reason (age) my internal valves on my shocks are not holding the correct fluid pressures, this will also transfer to my ride quality when driving. My decision was made right then to make the change.
Old Dec 8, 2010 | 10:01 AM
chazaroo's Avatar
Based on mileage alone, I'd say shocks are needed. Bet you'll notice a dramatically different ride once you replace 'em.
Old Jan 25, 2011 | 07:24 AM
onin16's Avatar
hey guys, what is the difference between the OEM shock (98XK8) from the dealer and the bilstein or other brands? coz im planning to change my rear suspension next month. what should i look for? or anything else should be replaced or check other than suspension?
guidance needed please! Big thanks!
Old Jan 25, 2011 | 07:30 AM
chazaroo's Avatar
I think the main difference is dealer cost. I switched to Bilstein and noticed a great improvement in ride. I believe I paid around $100 per shock.
Old Jan 25, 2011 | 07:39 AM
onin16's Avatar
almost the same price as the OEM. I just replaced last month the front shocks for the same price $100each (OEM dealer)but forgot to change to bushes and the mount so i have to do the front again together with the new ones at the rear.
Old Jan 25, 2011 | 07:48 PM
H20boy's Avatar
yup, on the front, the upper mounts should always be checked...most dry out and fall apart, hindering the ride quality. Front gives me the most grief, sway bar bushings, and those dang control arm bushings...in the rear, I've had no other problems besides a lower shock bushing, but I think those failures are uncommon.
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
mrplow58
Sep 9, 2015 11:27 AM
EZDriver
Sep 8, 2015 09:25 AM
Busa R
Sep 3, 2015 05:01 PM
