engine wont start
Old Mar 18, 2013 | 07:54 PM
mike lomai's Avatar
Default engine wont start
i change the oil in my xk8 yesterday and turn the car on for a few seconds to move it. next morning the engine rotate but wont start. battery is ok. relays and fuses are ok. fuel pump seen to be working. can some one help me please.
Old Mar 18, 2013 | 08:20 PM
Mike,
I've moved your post from General Tech Help section to XK8/XKR section. You'll get advice from more members with the same vehicle here.
It'll help if you add details of Model Year and any codes.
Old Mar 18, 2013 | 08:35 PM
WhiteXKR's Avatar
Begin here https://www.jaguarforums.com/forum/g...d-first-30792/
and
Cylinder Wash - is this your problem? Did you run your engine for just few seconds or a minute, and now it won't start?
Detailed Procedures for Starting an Engine that ran for a moment and now won't start. (thanks Gus).
Old Mar 18, 2013 | 08:50 PM
dsnyder586's Avatar
+1 bore wash
Old Mar 18, 2013 | 09:09 PM
Fedoraja1's Avatar
I had the exact same issue. Never did figure out what was wrong with it.
If you conclude that it's not cylinder wash and it still won't start then take it in to a place that you trust or take it to a dealer. Please do whatever you can to avoid the situation I'm in.
Old Mar 19, 2013 | 05:10 PM
mike lomai's Avatar
Default mike
thanks for the helpful tips my car is up and running, saved me from going to a dealer...
on another note, i have an 2001 xk8. before disconnecting the battery the windows used to go slightly dwn when i opened door and slightly up when i shut the door, now it does not who can explain how to get it to go up and down slightly when opening and closing door...this happened to me before but it went back to its memory eventually like a month later...
mike
Old Mar 19, 2013 | 05:53 PM
enderle's Avatar
Default Resetting Windows
mike
You need to reset the windows every time you disconnect the battery. You do this by putting the window all the way up and continuing to hold the button until you hear a little click then run the windows down and hold until you hear that same click. Windows are then reset and should work fine.
Old Mar 19, 2013 | 05:54 PM
Paul Pavlik's Avatar
mike
Reset the Window Memory:
With the Door Closed, Raise the Window and continue to hold the Switch on for 3 more seconds.
Repeat for Window Down.
Repeat for Other Door.
Old Mar 19, 2013 | 08:42 PM
Gus's Avatar
Gus
What did you do to get it running?
mike
D.K
Dec 10, 2023 02:05 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
