Footrest Pedal Removal
Old Apr 10, 2011 | 01:44 AM
JRE-xkr's Avatar
Default Footrest Pedal Removal
I would like to remove the footrest pedal on my '01 XKR, how is it attached? What is the removal procedure?
Thanks,
Jim
Old Apr 10, 2011 | 08:26 AM
WhiteXKR's Avatar
See the attachment
File Type: pdf
Old Apr 10, 2011 | 09:21 AM
JRE-xkr's Avatar
White XKR,
Thanks for the info, I also have pictures of the J gate screws from Jaguar that you asked for, but don't know how to post them on here.
Jim
Old Apr 10, 2011 | 04:10 PM
JRE-xkr's Avatar
Well,
I tried to pull the pedal off but did not get anywhere. Is there some method to pull it off?
Thanks,
Jim
Old Apr 10, 2011 | 05:25 PM
Fjk's Avatar
Fjk
The extension is held by two tabs. One at the top, the other at the bottom. If you feel the top of the extension, reach under the sides of the tab and raise it while pulling. top is easier to un-latch. You must pull pretty hard..
I made an extension out of AL. bar stock. Drilled and tapped both ends. (6mm) Six mm stud in one end, to screw into the floor, and the other accepts the existing foot rest base.
Old Apr 10, 2011 | 07:09 PM
JRE-xkr's Avatar
Fred,
Thanks for the info, I just bought a set of Arden pedals, and it looks like the Arden footrest goes over the factory Jaguar extension.
Old Apr 11, 2011 | 07:37 AM
K.Westra's Avatar
Originally Posted by JRE-XKR
Fred,
The Arden pedals look great, but holy cow are they expensive! I'd love to see some pics when you get done, most of the pictures I've seen are not installed or so small its difficult to see.
Old Apr 11, 2011 | 11:15 PM
JRE-xkr's Avatar
I will post some pictures when I finish the interior. Yes the Arden parts are VERY EXPENSIVE! I have their wheels, J-gate surround, shift knob, steering wheel, airbag cover, and pedals... so far. I talked with Arden about a dealer discount and they offer a 25% discount to dealers. I would not be able to sell enough parts to make it worthwhile. Some of the parts I was able to get from a dealer who was closing out his old Arden stock and was able to get some parts for 25 cents on the dollar.
Jim
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Lannyl81
Sep 19, 2015 08:07 PM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
hen555
Sep 7, 2015 11:13 PM
