Front spring packers
Old Feb 23, 2019 | 09:11 AM
Higgins's Avatar
Default Front spring packers
I am doing a lot of work in the front end of my Xkr 2000 year model. Now I am planning for the re-assemble of springs and dampers but I am confused about one detail. When disassembling the springs some time back I found out that there where two spring packers at each spring. There where also a third plastic ring, thicker than the two black packers and also having a few guidance brackets on it for keeping the spring centered.
Is this standard fitment? When looking at Sng Barratt site it looks there should only be one black spring packer, nothing else
Old Feb 23, 2019 | 09:44 AM
Johnken's Avatar
Higgins, the white one is standard. Be careful of it, I've seen several posts from folks who accidentally broke it.
I dont recall the other two, which just means I don't remember that level of detail. Someone else will surely remember better than me.
John
Old Feb 25, 2019 | 02:26 AM
Higgins's Avatar
Thanks Johnken. No one else seems to be able to share their knowledge here. Strange difference in fitment in reality compared to what Sng Barratt specifies. Now I replace the old stock springs with lowered ones from Adamesh, I have also bought one new black spring packer per side from Sng Baratt, but I guess I will try to reuse the old white one as well that has the guidance parts for the spring on it.
Old Feb 25, 2019 | 06:41 AM
If I recall correctly - I had 2. trying to locate pics
Old Feb 25, 2019 | 06:54 AM
see post 14 in this thread - shows the spring packer area. The black one which I believe was metal rides on the ring that goes around the recessed groove on the shock, then the white one sits on that
https://www.jaguarforums.com/forum/x...mounts-104217/
Old Feb 25, 2019 | 01:16 PM
Higgins's Avatar
Then there has been different setup for different models or model years. My black spring packers are in plastic. I think I will just try the same setup my car had when I took things apart. And lets see how it turns out
Old Feb 25, 2019 | 02:14 PM
rothwell's Avatar
From the repair manual Section 204-01
"Springs come in various ratings depending on the vehicle's suspension specification The suspension specification also determines the
number of packers fitted between the lower spring pan and the spring."
It would be prudent to put it back together the way you found it.
Old Feb 25, 2019 | 02:44 PM
RaceDiagnostics's Avatar
Your are lucky they are in one piece, I read here that they come with new springs direct from Jaguar but not aftermarket but also read they are NLA even from Jag, they never had their own part number either.
Mine didn't look too good. FYI, when I reassembled mine I only included one black packing washers to reduce the front height a bit.
Old Apr 14, 2020 | 09:09 AM
TheDude3's Avatar
RaceDiagnostics, did you end up just leaving out the white ring altogether and just using one black ring, or did you source another white ring?
Daniel.angeles001
Jul 23, 2018 11:33 AM
RaceDiagnostics
Nov 8, 2014 08:43 AM
megatrack
Jun 18, 2011 02:18 PM
brgjag
May 5, 2010 07:57 AM
grommet
XJ40 ( XJ81 )
Feb 28, 2009 06:45 AM
