Which fuel filter?
Old May 26, 2012 | 03:50 PM
K.Westra's Avatar
Default Which fuel filter?
I want to change the fuel filter, both because I don't think it's ever been done, and because I think it may be contributing to my very intermittent "Restricted Performance" outlined here. It should be easy enough to do since it is in line rather than in tank. I checked out RockAuto.com and they have several listed:
Code:
PRONTO 		PF3144 {#DF9864}  Engine VIN C 				$ 1.91
PENTIUS 	PFB33144    Engine VIN C 				$ 2.17
ACDELCO 	GF652  {#25055052,25171792,GF481} Replaces GF481	$ 9.22
FRAM 		G3727  In-Line Gasoline Filter 				$ 9.63
WIX	 	33481							$10.04
BECK/ARNLEY 	0430909  						$10.79
MANN 		WK6122  						$13.92
MAHLE 		KL158 In-Line; Ht: 107mm; Outside Diameter: 55mm 	$17.25
It appears that any of these will fit, but why the range in price? Are the pricier ones really better filters? Anyone have a recommendation? I'm tempted to just go with either the AC Delco, Fram, or Wix since I'm familiar with the brands at least, but I thought I'd ask the collective XK8/XKR brain trust on this one, since you guys always steer me right
Old May 26, 2012 | 03:57 PM
RJ237's Avatar
I like Mann filters, but that's just a holdover from my BMW days.
RJ
______________________
1997 XK8 Conv. 85K mi.
Old May 26, 2012 | 04:05 PM
K.Westra's Avatar
After a quick search (sometimes even senior members forget to do that, lol), I see I should cross reference a 1988 Chevy Pickup to save a bit, so that leads me to the Wix filter since I can pick one up locally and a quick cross-reference shows the same part number there, so I may just head to the parts store, unless someone can offer a compelling reason to spend more for one of the pricier filters.
EDIT: I see a vote for Mann. I think I can pick up one of those locally too, and they aren't much more, so that sounds good. I am thinking those "Pronto" filters must be absolute crap based on their price.
Old May 26, 2012 | 09:24 PM
RCSign's Avatar
As written by Keith
If I was ordering a filter, I replaced mine this spring with a AC/ Delco, I would by a pronto and Pentius just to cut it apart to see the difference if any, sometimes you never know. It could be the same filter.
Old May 27, 2012 | 05:56 AM
Stumpy's Avatar
Thumbs up
I agree that would be interesting, and cut apart the original as well to compare all 3.
I fitted a Jaguar part, as you don't want any danger of lean mixture problems under acceleration!
Old May 27, 2012 | 09:54 AM
Originally Posted by K.Westra
............I'm tempted to just go with either the AC Delco, Fram, or Wix since I'm familiar with the brands at least, but I thought I'd ask the collective XK8/XKR brain trust on this one, since you guys always steer me right
Keith,
I hope this is a quality and not a money saving question! Compared with the cost of the fuel you've used, a gold plated replacement filter would be insignificant $$.
I'd also go for AC Delco, Fram or Wix as the leading brands. AC Delco are OE suppliers to many UK motor manufacturers so this one would tip the balance for me as it's likely to be the same as the one in a Jaguar box.
Old May 27, 2012 | 11:41 AM
Jon89's Avatar
Purolator and Wix fuel filters have always worked just fine for me....
Old May 27, 2012 | 03:17 PM
K.Westra's Avatar
Certainly is a quality question Graham.
Old May 27, 2012 | 03:40 PM
Stumpy's Avatar
Question
Just out of interest how much would a Jaguar one cost where you are?
Old May 27, 2012 | 04:10 PM
Gaudin lists it at $22.66.
2000 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
Old May 27, 2012 | 06:51 PM
RJag's Avatar
I don't know about the fuel filter but the Wix air filter is exactly the same as the oem Jag filter. Wix makes them for Jag.
Old May 27, 2012 | 07:34 PM
Stumpy's Avatar
Originally Posted by Norri
Well at that price I personally wouldn't even be bothering to find an alternative.
Old May 28, 2012 | 04:10 AM
I just purchased an oil and air filter from my local Jaguar Dealer last Friday.
The Air Filter came in a box labelled 'Made to Jaguar specification in Germany'. It contained a fliter stamped 'Made in Poland'!
Both the Oil Filter and its box were labelled 'Made in Germany'
Old May 28, 2012 | 08:20 AM
Didn't Poland used to be part of Germany?
Old May 28, 2012 | 09:03 AM
Stumpy's Avatar
Old May 28, 2012 | 04:35 PM
plums's Avatar
Apparently there is a difference between "manufactured in" and "made in".
Take a a look at the packaging on a Quaker State filter wrench some time.
"Manufactured in the USA" is on the packaging. "Made in China" is on the wrench. And there is some blurb highlighting the USA part, never mentioning the true source of the actual wrench. So, "manufactured in the USA, via China" would be more truthful. The acutal wrench that you hold in your hand is from China, the packaging you throw away is from the USA.
"Manufacturing" can be something as minor as final packaging or applying a UPC bar code sticker.
Old May 29, 2012 | 02:01 PM
Stumpy's Avatar
Same here in the UK
Salmon from anywhere in the world can be labeled as "Scottish Salmon" as long as it is tinned there!
silkcat
Jan 18, 2025 04:29 AM
JWheeler
Nov 22, 2019 08:28 AM
shootingbrake
Sep 23, 2015 10:54 AM
axr383
Sep 18, 2015 11:19 AM
Sprayall
Sep 3, 2015 07:49 PM
