Fuel Pump & Filter
Old Sep 12, 2010 | 01:51 PM
Gus's Avatar
Gus
Default Fuel Pump & Filter
I recently experienced a fuel pump failure on my 1999 XK8 and elected to replace the filter at the same time. Attached are my findings on the pump failure.
http://www.gusglikas.com/images/Auto...FilterPump.pdf
Old Sep 12, 2010 | 08:10 PM
daddyo007's Avatar
Gus, I bet when you were little you were the kid who loved dissecting the frog just to see if you could find the croaker!
How bad was it to get the pump out of the car?
Old Sep 12, 2010 | 08:34 PM
Gus's Avatar
Gus
Not bad just painful $650.00! I do not have the location to do it and I was pressed on another project. Sorry!
Old Sep 13, 2010 | 07:55 AM
oldmots's Avatar
If I found an AC filter in my car, I would assume it had been replaced. Any Jag I have had since new always had filters that said Jaguar on them. Nice study, thanks for the pics.
Old Sep 13, 2010 | 11:04 AM
Gus's Avatar
Gus
Under normal conditions I would agree with you but what I am finding from my 1993 XJ-S, 1995 XJ6, 1999 XK8 & 2000 S-Type you will find interchangeable parts from Ford, GM, MB & Jaguar and it would not surprise me to see a few others in the mix. I guess it is out to the lowest bidder.
Old Sep 14, 2010 | 02:20 PM
AlexXK8's Avatar
Yep, When I replaced mine at 72K on my 2002XK8 under the AC were the words Coventry, England
Old Sep 14, 2010 | 09:24 PM
BurgXK8's Avatar
Default Just did mine this evening.
Not the pump, but the filter. And it said Jaguar on it, not AC. Could not tell if it was original, but it looked like it could have been. Replaced it with a Wix for about 15 bucks and thirty minutes of wrench work.
How'd you get your old filter open? Ordinary can opener? I might pull mine out of the trash and see what's in it....
Old Sep 14, 2010 | 09:34 PM
Gus's Avatar
Gus
I used a body saw to cut it open.
http://www.sears.com/shc/s/p_10153_1...&blockType=G12
Old Sep 14, 2010 | 09:47 PM
WhiteXKR's Avatar
That seemed to work well.
I got one of these to open up my oil filter for inspection and avoid contaminating it with metal: http://www.jegs.com/i/JEGS/555/80532...oductId=753437
Old Sep 14, 2010 | 09:49 PM
BurgXK8's Avatar
Wow -and I thought I'd seen every kind of tool out there! An oil filter cutting tool - who knew?
Old Sep 14, 2010 | 09:58 PM
WhiteXKR's Avatar
My wife already has the tool sale planned in case I meet an untimely end.
Old Sep 16, 2010 | 08:49 AM
dneider's Avatar
Gus I opened one of my failed pumps and it looked almost identical... melted plastics and all.
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
