Fuse location for convertibale top?
Old Mar 22, 2010 | 07:58 PM
RSA Esq's Avatar
Default Fuse location for convertibale top?
Can anyone direct me to the fuse location for the converible top control on my 2000 XKR? It quit working and I suspect a blown fuse. But there are too many fusaes and no diagram (that I can find). Help!
Thanks!
Ray
Old Mar 22, 2010 | 08:12 PM
Gus's Avatar
Gus
What is taking place that you think you need a fuse? Not avoiding the question just want to help.
Old Mar 22, 2010 | 08:16 PM
RSA Esq's Avatar
Putting the top down yesterday and the little windows went down and then nothing. The dispay on the dash indicates that the top isn't latched, but it seems to be secure. Top (and little windows) won't go up or down now. Of course, the manual tells me to take it to the dealer. $$$
Thanks!
Old Mar 22, 2010 | 08:34 PM
Gus's Avatar
Gus
Your windows will not go up until the latch is completely latches at the header. It sounds like either your roof is out of sequence or you have a hyd leak. Do you have evidence of a leak and do you know where your pump is? I have a lot of information on the roof system on my page if you wish to read.
Old Mar 22, 2010 | 08:46 PM
RSA Esq's Avatar
No leak. And I can't get the roof to do anything. I'll take a look at your website. But I would still like to check the fuse, if you know which one it is.
Old Mar 22, 2010 | 08:51 PM
Gus's Avatar
Gus
It is in the trunk next to the battery.
Old Mar 22, 2010 | 08:52 PM
Gus's Avatar
Gus
The fuse is located in the trunk and you have relays for the roof. Not knowing the year of your car you can select it at http://www.gusglikas.com/AutoRepairElectrical.htm for the fuse and relay location is in the trunk next to the battery. As for the location of your pump it is in the right rear above the CD. This link might help you to get access http://www.gusglikas.com/AutoRepairJ...esRelValve.htm Now in the shelf of the pump you will find the allen wrench. This wrench is used to manually open and close your header latch. Your windows will not open or close until the system is completely satisfied and a leak or low fluid in the system will prevent this from taking place. http://www.gusglikas.com/AutoRepairH...lOperation.htm Read the last paragraph.
Old Mar 30, 2010 | 06:07 PM
RSA Esq's Avatar
Thanks for all your help, Gus! But after having no luck diagnosing the problem myself, I finally took the car to the Jaguar mechanic today. He found the left side ram was leaking fluid. He's replacing both rams as well as flushing the system and adding the newer hydraulic fluid recommended by Jaguar.
Thanks again,
Ray
Old Mar 30, 2010 | 07:15 PM
test point's Avatar
You might also read Gus's discussion on the pressure relief system he caused to be developed. Adding that little unit will avoid another $1200 in hydraulic hose repair.
Old Mar 30, 2010 | 10:24 PM
Gus's Avatar
Gus
Yes the right hand ram is one of the keys to operating the windows. If it is not locked into the closed position the micro switch is not activated and the windows will not work. Is your roof hose OK? Now would be a good time to look at it now that the back is open and available.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Rivguy
Dec 4, 2020 07:55 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
motorhead69
Sep 9, 2015 10:04 AM
