gear box fault - RESOLVED
Old May 19, 2014 | 04:42 PM
Veteran: Navy
Default gear box fault - RESOLVED
well 2 years and 3 months of semi trouble free driving pleasure have passed. Now dealing with a gearbox fault, CEL and 1722 code - just glad it decided to show up after I got off the interstate!!!
She gets a piggy back ride tomorrow to the indie for a look. I've read the previous threads on this - so hoping it doesn't require replacement and can be repaired.
Either way, hope to have her back on the road this weekend - driving a Smart car just does not take the place of my Jag!!!
regards,
steve
Old May 19, 2014 | 04:54 PM
Jon89's Avatar
I hope the solution turns out to be both relatively painless and relatively inexpensive. Good luck, and keep us posted....
Old May 20, 2014 | 05:16 AM
Veteran: Navy
thanks Jon - wish I had the time and space to do myself!
Old May 20, 2014 | 08:27 AM
jafari's Avatar
Hope it's not too serious! I had a gear box fault that showed up with a Throttle Body fault (can't remember which one). I disconnected, cleaned, jammed and reconnected all TB connectors and the gearbox error never came back. So you see, it may well be a simple electrical thing that has nothing to do with the gearbox
Old May 20, 2014 | 07:33 PM
Veteran: Navy
well so far they found four codes in three separate systems that indicate a probable issue with the transmission speed output sensor; checked the fluid level and inspected the fluid. The level is o.k., but the condition of the fluid is burnt and black.
dropping the pan for further inspection
If you have not done so - check/replace the transmission fluid - sealed for life is BS.
Old May 20, 2014 | 10:03 PM
Gus's Avatar
Gus
Take it from one who knows take the plunge and have the transmission done correctly. Have them check and replace as necessary.
Old May 21, 2014 | 07:45 AM
Veteran: Navy
Gus - no doubt - read what you went through and don't want to go through that.
Old May 22, 2014 | 03:30 PM
Veteran: Navy
well - to rebuild or replace?
Old May 23, 2014 | 08:04 AM
Gus's Avatar
Gus
Both are rebuilt.
Old May 23, 2014 | 08:25 AM
Veteran: Navy
Gus -thanks probably should have been more clear on my statement as I've was searching the web and saw a used one for about $900 and rebuilt units anywhere from 1500-2500. A used leads me further into unknown territory - so most likely will rule that out.
Old May 29, 2014 | 05:24 PM
Veteran: Navy
just to update - rebuild has commenced and hope to have her back on the road next week. Driving my daughter's Smart car just doesn't compare - oi vey!!!!!
Old Jun 4, 2014 | 12:44 PM
Veteran: Navy
tranny rebuild complete and install underway. Hope to have her back on the road tomorrow!!!!!
Old Jun 4, 2014 | 06:19 PM
H20boy's Avatar
good luck!
Old Jun 6, 2014 | 03:43 PM
Veteran: Navy
tranny rebuilt to include new torque converter (2yr/24Kmile warranty), replaced crankshaft seal and an O2 sensor they damaged during removal - we are mobile once more!!!
Old Jun 6, 2014 | 04:13 PM
p-Rock's Avatar
Who did you take it to Steve?
Old Jun 6, 2014 | 04:26 PM
Veteran: Navy
I took it to Charleston Import Automotive off of Ashley Phosphate as it started off as a sensor and they give a discount for JCNA members. But when they dropped the pan and saw the shrapnel, they had Holt Transmissions do the rebuild.
Old Jun 6, 2014 | 04:41 PM
The Coupe's Avatar
Do you mind telling us how much the rebuild cost you?
Old Jun 6, 2014 | 05:02 PM
Veteran: Navy
total parts/labor was $3572. Tranny rebuild itself was $2300 which is comparable to what I found on line ($2250 with 12month/12kmile warranty +core and shipping)
Old Jun 6, 2014 | 07:26 PM
The Coupe's Avatar
Thanks. So was the additional $1200 all for labor (removing the old trans and installing the rebuilt one)?
Old Jun 6, 2014 | 09:33 PM
Veteran: Navy
labor, taxes, fluid & crank seal, environmental fees
