Help! Anybody got any bright ideas on removing rear damper bush
Old Aug 20, 2011 | 12:47 PM
PaulJ's Avatar
Angry Help! Anybody got any bright ideas on removing rear damper bush
I am trying to remove the lower rear damper bush I have made up a tool using sockets and threaded rod to get it out as per the post on here. Soaked it with plus gas applied heat albeit it's not a big blow torch just one of the butane canister units and in desperation hit it a few times it won't budge.
The threaded rod it's M12 has now stripped albeit I have plenty.
I am at the point that I can put it all back together however if I do much more I might destroy the old bush completely and then not be able to but it back together to drive it to a garage to do.
I hate being defeated so appreciate any ideas on how to get the bush out
Old Aug 20, 2011 | 12:51 PM
plums's Avatar
Not specific to your bushing. But, some guys will burn/char a rubber bushing with flame if it is being stubborn. Usual safety precautions around flames and flammables apply.
Old Aug 20, 2011 | 01:03 PM
PaulJ's Avatar
The problem with this bush is it has a steel sleeve around the rubber and that's what I reckon has corroded in the damper.
Old Aug 20, 2011 | 01:27 PM
plums's Avatar
So, drill holes in the rubber along the same axis as the bolt. Knock the rubber bit out. Hacksaw the steel sleeve along the same axis to relieve pressure. Squeeze out.
Or apply pressure with your tool. Then, bang against the outer eye of the shock with medium force. This usually breaks the corrosion and each bang the seized part will move just a tiny fraction, but it will move in the right direction. It's the same reason impact wrenches work so well.
Old Aug 20, 2011 | 02:47 PM
Brutal's Avatar
Air chissel to cut the sleeve and drive the bushing out all at the same time. I did some this morning
Old Aug 20, 2011 | 03:42 PM
PaulJ's Avatar
Plums I had thought of the hacksaw approach just a bit worried about damaging inside of damper sleeve. Maybe try your other idea first.
Brutal I only wish I had a compressor as I am sure it would make many jobs easier.
Old Aug 20, 2011 | 03:49 PM
You don't need to saw all the way through if you are nervous, you just need enough to weaken it then you can either drive or draw it out.
Old Aug 20, 2011 | 04:34 PM
plums's Avatar
exactly.
The apply pressure and bang is easier though
Old Aug 20, 2011 | 05:01 PM
xenophobe's Avatar
There are plenty of inexpensive air compressors. If you have Amazon Prime, this 3 gallon compressor is $75 shipped:
Amazon.com: Campbell Hausfeld FP209499 3-Gallon Air Compressor: Home Improvement
Old Aug 20, 2011 | 08:17 PM
bt965's Avatar
Take the whole shock/spring assembly to a friendly local workshop and ask nicely to press out, may have to grease a greasy palm,if your not experienced at cutting/chiseling.
Because you still have to get new one in and if you damage the bush housing by bashing it, your gonna be fu*&%D.
Or try threaded bar with finer thread
Old Aug 20, 2011 | 10:37 PM
plums's Avatar
Buying the compressor is the easy part. But some people have no place to put it.
Old Aug 21, 2011 | 12:12 AM
Reverend Sam's Avatar
BLASPHEMY!!! Men can always find room for tools.
Old Aug 21, 2011 | 01:42 AM
plums's Avatar
Ok, double entendre aside, tell that to the landlord
Raul Lara
Sep 14, 2015 07:31 PM
davidladewig
Sep 3, 2015 06:32 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
