Help- keys locked in trunk
Old Feb 12, 2012 | 05:04 PM
mikeeadyjr's Avatar
Angry Help- keys locked in trunk
I HAVE JOINED THE KEYS LOCK IN THE TRUNK CLUB HELP ANYONE PLZ
Old Feb 12, 2012 | 05:24 PM
Sqeeter91's Avatar
where's your spare set?
cutting torch? Good luck?
Old Feb 12, 2012 | 05:27 PM
Count_Damonee's Avatar
I quess you tried pushing the button on the Trunk???
Or the one in the Cabin on the left side by the fuel release???
You closed it and it Locked the whole vehicle???
We could try this....
http://www.youtube.com/watch?v=_C5ro4eRi78
Old Feb 12, 2012 | 06:03 PM
mikeeadyjr's Avatar
Only have the v-key
Old Feb 12, 2012 | 06:08 PM
2002XK8Orlando's Avatar
If you haven't pushed the valet button then the valet key will open the trunk
Old Feb 12, 2012 | 06:28 PM
mikeeadyjr's Avatar
Tried it didn't work
Old Feb 12, 2012 | 06:32 PM
The XJ owners seem to specialise in this. Their solution is to remove the licence plate and use a small screwdriver through the square holes to trip the lock lever. Here's a thread on the topic:
https://www.jaguarforums.com/forum/x...d-58948/page2/
If the XK8 lock mechanism is similar (I don't know), it could be worth a try.
Old Feb 12, 2012 | 06:34 PM
Well if it will open the door but not the trunk you must be in 'valet' mode...I locked all of mine in the car..ever f'ing key for the car. Had to go to dealer and have key cut
Old Feb 17, 2012 | 09:09 AM
mikeeadyjr's Avatar
I had to get a new key $198 for the key and $90 to program the key
Old Feb 17, 2012 | 09:24 AM
Expensive mistake I'm afraid, sorry we couldn't help more
Old Feb 17, 2012 | 10:34 AM
So did you get the new key programmed before opening the trunk?
If so does that mean that the original key doesn't work and you need to have both programmed now?
Am I right in thinking that an unprogrammed key would have opened the trunk then they could both have been done together?
Old Feb 17, 2012 | 12:21 PM
mikeeadyjr's Avatar
Programming the key is for starting only. It does everything minus start the car. After I get the key out the trunk i have to take the car in for them to program the key to the car.
Old Feb 17, 2012 | 01:36 PM
That was my point, are they going to charge you again?
They will have to re-programme both keys, old and new.
Old Feb 18, 2012 | 06:20 AM
mikeeadyjr's Avatar
Just the new one they haven't program yet to unlock the doors it doesn't need to be programed
Old Feb 18, 2012 | 06:23 AM
mikeeadyjr's Avatar
yes they will charge me the $90 when I bring it in
Old Feb 18, 2012 | 06:43 AM
Ok my mistake, I thought they had cut and programmed the new one.
Old Feb 18, 2012 | 09:28 AM
motorcarman's Avatar
"ALL KEYS MUST BE PRESENT. KEYS NOT PRESENT WILL BE DELETED. DO YOU WISH TO CONTINUE?"
That is the message on the screen when programming key transponders to the vehicle.
You cannot ADD KEYS later, so have all keys with you when you get the new key configured to the vehicle.
If you want to drive about 500 or 600 miles to Decatur TX, I can programme them for you (with WDS), but it will be cheaper to have the dealer there do it.
bob gauff
Old Feb 18, 2012 | 12:21 PM
oldjaglover's Avatar
You can buy key reprogramming kits on ebay for about$10, and new fobs either come with them or can be purchased for about $10-30. Of course, it probably won't say "Jaguar" on it. My wife used one of the reprogramming kits for her Nissan and it worked fine. I'm thinking about getting one for each of my vehicles just in case (although I do keep an extra key in my other pocket or at home all the time).
Old Feb 18, 2012 | 07:59 PM
Felipe Pr's Avatar
I tried a search in ebay for the key reprogramming kits and it returned 0 items.
Old Feb 18, 2012 | 08:54 PM
North American spec. 1997 XK8 does not have a key transponder. There is no KTM, keys do not need to be configured.
All Jaguars for NA started the KTM setup in 1998MY onward.
bob gauff
