Help with Odd Issue
Old Oct 18, 2024 | 12:54 PM
json125266's Avatar
Exclamation Help with Odd Issue
Hi all,
I recently got this error when starting up the 2002 XK8. Immediately upon start up I got a whole bunch of new errors, which i never had before.
1. Low Brake Fluid
2. Incorrect Part Fitted
3. Failsafe Engine Mode
4. Transmission Fault
5. ASC Not Available
6. Incorrect Part Fitted
Also,
6. Check Engine light is on,
7. ABS light is on
8. Parking Brake light is one (Parking brake was not engaged)
9. Car can be started but,
10. Car cannot move out of park
11. All dash gauges are not updating (RPM, Speed, Temp, oil pressure) Fuel gage bounces around!
I hooked up my scan tool, and was able to pull the following codes.
P1638 - CAN link engine control unit/Instrument cluster/network malfunction
U1135 - Ignition state not obtained
U1041 - SCP vehicle speed signal - invalid or missing message
Link to fuel gauge gif.
https://i.giphy.com/media/v1.Y2lkPTc...ized-large.gif
Anybody have any idea what this could be? Am I looking at a ECU issue?
Old Oct 18, 2024 | 01:33 PM
Jon89's Avatar
First things first. How old is your battery?
Old Oct 18, 2024 | 01:34 PM
Y2KJag's Avatar
Often when you get loads of oddball codes it means you have a low voltage problem. Check your battery with car off, and check the voltage when car is running.
Old Oct 18, 2024 | 01:43 PM
Chirpy's Avatar
Battery low voltage is definitely the first thing to rule out.
If that is not the problem, then the "P1638 CAN INST token message missing error" could point to the INST pack can bus solder blob issue, although I thought that was on 2001 cars only....or possibly some other issue with the instrument pack. Anyway, browsing threads on that theme might indicate whether others had similar symptoms....
(e.g.https://www.jaguarforums.com/forum/x...cement-216270/
https://www.jaguarforums.com/forum/x...t-help-134978/
https://www.jaguarforums.com/forum/x...luster-228872/
etc. )
Old Oct 18, 2024 | 01:45 PM
json125266's Avatar
forgot to mention, battery is brand new ( ~3 months old), and was on a tender prior to this.
Old Oct 18, 2024 | 04:16 PM
zray's Avatar
i would still have the battery load tested.
Old Oct 22, 2024 | 11:16 AM
json125266's Avatar
Update: I checked the Instrument Cluster rework, and it seems like it was already done, or likely out of the affected lot.
Still need to do a load test on the battery, but does anyone have anything else to check?
Thanks in advance
Jay
The M signifies ",modified" backplate
No indication of solder migration
Old Oct 22, 2024 | 12:27 PM
RJ237's Avatar
Check that the bellhousing to chassis ground strap is clean and tight, same for battery and bulkhead connections.
ehostin
Mar 12, 2024 02:13 PM
jschimmels
Sep 4, 2018 10:37 PM
Enosgl
Dec 18, 2017 08:11 PM
Xcellr8
Jul 27, 2011 11:12 AM
Jerrys Ride
Dec 2, 2010 04:54 AM
