Help Secondary tensioner bolt sheared off!
Old Jun 28, 2014 | 10:38 AM
steeevo's Avatar
Default Help Secondary tensioner bolt sheared off!
Well as you can see everything was going so well was just putting the new tensioner bolts in and one sheared while i was using a brand new teng tools torque wrench triple checked the torque setting and i must have had a crap bolt!
just what i needed........... please help my backs hurting
Old Jun 28, 2014 | 01:26 PM
test point's Avatar
Take the other bolt out and you may be able to remove the tensioner depending on how much bolt remains in the tensioner body. If it is too long to slide off the bolt you are going to have to remove the exhaust cam sprocket to get enough room under the chain. Without any tension on the bolt it should just screw out unless it is broken off down in the threaded hole.
Don't know if you have cam alignment tools or are using the zip tie method but either should allow you to remove the tensioner.
The bolts are available at any Ford store here but don't know about merry ol' England.
Old Jun 28, 2014 | 01:58 PM
steeevo's Avatar
Old Jun 28, 2014 | 11:27 PM
johns55's Avatar
Old Jun 29, 2014 | 03:50 AM
steeevo's Avatar
With a junior hacksaw then chamfered the ends and test fit them.
The original bolts were alot better than the ones i received. Made the job 2 hours longer and i just wish they supplied better bolts
Old Jun 29, 2014 | 04:22 AM
ArtyH's Avatar
Talking
Your tensioner's look the same as mind did, you may have sheared a bolt but you dodged a bullet. Good job and glad you got it sorted.
Old Jun 29, 2014 | 07:42 AM
steeevo's Avatar
Yeah i can't believe how bad it was when i got it removed you can even see where the chain has been rubbing on the metal where the shoe has should have been. i hope to shoe is in the sump and not gonna cause a problem.
one thing i did notice was that you don't have to do the bolts up that tight even the cam caps in the workshop manual say 9nm - 11nm and when i was doing it i thought this can't be right. but i did everything exactly as it should be so hopefully everything will be ok for now
Old Jun 30, 2014 | 03:15 AM
steeevo's Avatar
The culprit
Old Jun 30, 2014 | 06:25 AM
Fulton's Avatar
Nice work Steeevo,
Who ever sold you those bolts needs a good slap! Glad you got it sorted out and by the looks of the old tensioner, just in time. I'd drop the oil pan you probably have bits floating around you need to remove. Another XK8 saved from the wreckers, Yeah!
Old Jun 30, 2014 | 08:32 AM
dublinmike's Avatar
Well done Steeevo. Sounds like the job would have been a doddle without the sheared bolt incident.
Any other elements of the job you had a problem with? Used tiewraps?
Rgds,
Mike
Old Jun 30, 2014 | 08:48 AM
RJ237's Avatar
The pieces of shoe will be in the pickup screen for the oil pump. They may not restrict flow depending on how big they are, but I pulled the pan and removed them for piece of mind.
Old Jun 30, 2014 | 12:53 PM
steeevo's Avatar
Rgds,
Mike
It was only the bolts that added 2 hours on the job otherwise it would have been 4 hours just doing it slowly cleaning all the surfaces and parts with carb cleaner and making sure i got everything torqued correctly and didnt miss anything.
The cable tie method is pretty simple however the cam on the passengers side would not lift up when i was releasing the cam cap bolts so i got a big cable tie and wrapped it round the cam and kept pulling on it as i was releasing the bolts which took some time but after the cam caps were removed just be carefull lifting the cam up and wiggling the old tensioner out the way making sure not to let the spring drop down in to the engine. The drivers side cam just lifted out when i removed the cam caps and was simple im not sure why.
Also remember to remove the orange pin that keeps the new tensioner together after you have fitted it and put the cam back in place.
Also the torque settings dont feel tight but just trust your torque wrench. Get it done mate i cant believe how close i was to complete and utter mayhem. i have added some bg44 to the fuel with my last fill up and I'm sure the engine is running smoother and not so shaky anymore.
Looks like my guides are on their way out too.
Mac Allan
Jul 20, 2020 05:46 PM
X308XJR
May 20, 2019 06:50 PM
Dave1109971
Dec 15, 2015 06:16 PM
JAMES1944
Sep 29, 2015 11:58 AM
Collector1
Sep 26, 2015 05:28 PM
