Help in taking out air filter box
Old Jul 13, 2015 | 06:03 PM
XKR8's Avatar
Default Help in taking out air filter box
Hi Guys
can anyone help me understand how can i take off this bolt ( marked in red)
its attached to a rubber mount that spins as soon as i try to take it off.
its a 2001 XKR
THANKS
Old Jul 13, 2015 | 06:55 PM
WhiteXKR's Avatar
There is a VERY thin hex nut attached to the top of the rubber, under the plastic air-box flange. Grab it with a open -end wrench or a pair of vise-grips.
Old Jul 14, 2015 | 02:54 AM
XKR8,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post tech questions about your model.
Old Jul 14, 2015 | 05:01 PM
XKR8's Avatar
ok
i got it - never saw the stupid nut
thanks
Attached photos , what do you think?
will water from the vents on the hood and / or engine heat can harm this filter?
Attached Thumbnails Help in taking out air filter box-unnamed-10-.jpg   Help in taking out air filter box-unnamed-11-.jpg
Old Jul 15, 2015 | 06:10 AM
worrasf's Avatar
I think it looks nice and probably sounds a little throaty BUT, you are now going to be drawing in warm/hot air into that engine not the cool air it needs to run at it's best. While the standard Jag airbox may not look cool it actually provides cool air. I've measured the intake air temp with my Ultraguage and on the open road not stuck in traffic even on a warm day the intake temp is only a little above ambient. Received wisdom is that the cone filter like as not wont give you any increased horses either. There are cone filters that also have an attachment for a cold air intake duct.
Old Jul 15, 2015 | 06:44 AM
XKR8's Avatar
thanks for the info worrasf.
which cone filter would you recommend ?
Old Jul 15, 2015 | 06:56 AM
worrasf's Avatar
No recommendations from me I'm afraid as I stick to the OEM box. I had a dalliance with a piper cross on my Eunos but went back to the OEM box there as well. Other forum members may have suggestions but probably best trawling ebay
Old Jul 15, 2015 | 08:46 AM
regger21's Avatar
https://www.jaguarforums.com/forum/x...stions-104595/
https://www.jaguarforums.com/forum/x...results-74595/
There are quite a few threads addressing this very issue. The link above has a dozen or so photos of similar installs, notice several of them where they isolated the corner to create a cold air box. From my research on the forum it seems our cars can benefit from more breathing room....bored TB, 3.5" intake, larger MAF, etc. Interesting.
Old Jul 15, 2015 | 10:02 AM
XKR8's Avatar
thanks regger
Old Jul 15, 2015 | 11:22 AM
test point's Avatar
Is that the one that you have to treat with the proprietary snake oil?
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
bdboyle
Sep 4, 2015 06:16 AM
pocketrocket
Sep 3, 2015 07:44 PM
pnwrs2000
Sep 3, 2015 11:55 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
