iOS and OBDII
Old Jun 28, 2014 | 10:39 AM
giandanielxk8's Avatar
Default iOS and OBDII
Am I likely to have luck in using this:
Robot Check Robot Check
with the Jag and an iPad app? Is there a reason it couldn't work?
Old Jun 28, 2014 | 02:41 PM
SteveJacks's Avatar
I don't have this exact brand, but I do have an ELM321 compatible WIFI reader that I use with my ipad and iphone using dash command software
Old Jun 28, 2014 | 03:07 PM
Davebc's Avatar
Originally Posted by giandanielxk8
Am I likely to have luck in using this: Robot Check with the Jag and an iPad app? Is there a reason it couldn't work?
I have the same Elm use it with obd2 tooltech. Works ok, tells you codes, gives you revs speed etc, coolant temp and has a neat HUD feature that I haven't tested yet! It's a free app and works with both wifi and Bluetooth.
Old Jun 28, 2014 | 06:44 PM
Alright, I guess I'm going to get it. I won't have to rely on pep boys for those codes anymore.
Old Jun 29, 2014 | 10:45 AM
steeevo's Avatar
Im using dash command with an iphone and it works great. Good being able to clear codes but it doesnt clear the eml light
Old Jun 30, 2014 | 04:40 AM
Which is the eml light? Do you mean the CEL light?
Old Jun 30, 2014 | 02:31 PM
JagV8's Avatar
Yes, but it's properly the MIL. (See below)
Old Jun 30, 2014 | 03:31 PM
steeevo's Avatar
eml=engine management light thats what i thought it was called anyways.
Bcrary3
Sep 12, 2021 05:41 AM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
Ozzy_UK
Sep 24, 2015 08:44 PM
