J-Gate shifter gear lights not working Help
Old Jan 11, 2024 | 08:53 AM
joekluger's Avatar
Default J-Gate shifter gear lights not working Help
J-Gate shifter gear lights not working. None of my gear indicator lights on my shifter work. I replaced the 2 backlight bulbs and they work now but the indicator lights don't work. I see no switches for the shifter to hit to work the lights. Searched the forum with no luck. Any help would be great.
Old Jan 11, 2024 | 09:19 AM
motorcarman's Avatar
Old Jan 11, 2024 | 09:38 AM
joekluger's Avatar
Sorry... 1997 XK8 Convertible;
Also the Blue programing light does not come on to program the remote.
If someone can steer me in the right direction.
Old Jan 11, 2024 | 03:03 PM
The selector lever illumination module is a 'listen-only' node on the CAN bus.
I would read EVERY module on the CAN bus for DTCs.(the network wiring is a series twisted pair connecting the modules)
You can check the continuity of the network with an Ohm Meter to see if you have approximately 60 Ohms on the DLC pins 6 and 14.
Gus will have the electrical guide on his site. (jagrepair.com)
The NETWORKS are towards the end of the document S97_XK8.pdf.
Old Jan 11, 2024 | 03:16 PM
joekluger's Avatar
Did That... What should be next test.
Old Jan 11, 2024 | 04:37 PM
There are 5 nodes on the CAN bus. All except the selector lever illumination module can log DTCs.
You should interrogate ALL the modules for codes.
File Type: pdf
Old Jan 11, 2024 | 06:10 PM
joekluger's Avatar
WOW I'm lost. I thing this is beyond me unless these are some dummy instructions in how to do this.
Old Jan 11, 2024 | 06:41 PM
joekluger's Avatar
Where is the GEAR SELECTOR MODULE located. Would that be the circuit board under the shifter?
Old Jan 12, 2024 | 09:09 AM
What you are calling the J-Gate shifter gear lights is the part that Jaguar calls the selector lever illumination module.
Rex
Jun 3, 2023 03:17 PM
N Bath
XJ XJ12 ( X305 )
Sep 3, 2022 01:55 AM
grantorino62
Jul 1, 2018 09:34 PM
Lugnutty
Aug 30, 2014 03:47 AM
MyfirstJag
Sep 7, 2010 09:45 PM
