Location of Cabin/Pollen filter
Old Apr 19, 2010 | 02:14 AM
Thomasso's Avatar
Default Location of Cabin/Pollen filter
Can anyone tell me where to find the cabin/ pollen filter on my 01 XKR. Thank you.
Old Apr 19, 2010 | 08:46 AM
Brutal's Avatar
BELOW THE WIPER COWL, REMOVE THE WIPERS AND COWL, LOOK DEAD CENTER BELOW ON THE FIREWALL.
YOU SEE AN EMPTY SPACE AND A COUPLE OF STUDS, THOSE ARE TO ATTACH THE FILTER BOX AND FILTER, CAUSE i HAVE NEVER SEEN A US CAR WITH 1 FITTEED FROM THE FACTORY. THEYRE INSTALLED BY CUSTOMERS OR CUSTOMER REQUEST
Old Apr 19, 2010 | 09:30 AM
Thomasso's Avatar
Default Cab /Pollen filter
Thank you. No wonder I couldn't find it.
Old Apr 19, 2010 | 10:06 AM
jagpro69's Avatar
Default Me too
I spent 2 hours breaking down and putting back together my 06 XK8, trying to replace the pollen filter. It did not have one, but me and the car are alot closer now!
Old Apr 19, 2010 | 01:08 PM
stevepaa's Avatar
1 N07 http://www.captainjaguarscathouse.co...7%20ON/1_OF_3/
I added it.
Old Jun 24, 2010 | 12:05 AM
pdog2000's Avatar
where in the world can i order a pollen filter? for my 2001 XJR?
Old Jun 24, 2010 | 01:35 AM
avos's Avatar
If you google the partno MJD6863AA of the filter, you will see plenty of sources. The housing has partno MJA6865AA (ps both are for LHD cars).
Old Jun 24, 2010 | 09:39 AM
stevepaa's Avatar
description_______________________ #_________________ part no________ pic______ # ______MSRP
cabin air filter _____________________1_____________ MJA6863AA______ 1 N 07____ 2______ $73.00
filter housing _____________________1 _____Part number MJA6865AA was
superseded by part number MJD6865AA. ______________________1 N 07____ 1 ______$30.80
screws_________________________ 2 ______________JHG10625E ______1 N 07 ____3 _______$2.00
water shield _____________________1 ______________MJA6858AA______ 1N 07_____NL_____ $20.50
Try http://www.trademotion.com/partlocat...&siteid=214626
Attached Thumbnails Location of Cabin/Pollen filter-1_n_07%5B1%5D.jpg
Old Oct 31, 2018 | 01:18 PM
frazerriver's Avatar
Do I need a filter on my 2002 XK8? I recently bought it... I think the ac doesn't smell too fresh. Just by a can of AC cleaner spray?
Old Oct 31, 2018 | 01:46 PM
Jon89's Avatar
Is your XK8 a coupe or a convertible? The vast majority of the convertibles were not fitted with cabin air filter housings when they were built....
Old Oct 31, 2018 | 01:48 PM
Welcome to the forum frazerriver,
As you've landed on an eight year old thread with this question, it should be an indication of the value of pollen filters on the XK8! Rarely fitted and often soaked with water owing to the location, they are useless. If your XK8 is fitted with a pollen filter, throwing it away will help freshen the air. If not, then an AC cleaner should do the trick.
Old Oct 31, 2018 | 02:52 PM
Thank you very much I'll fill it out... Mine is a coupe. It does seem that here in Canada, same as US, there's likely not a filter but I'll take a look, I think I know where it's located, under the wipers.
Simon.
Old Dec 1, 2018 | 03:55 PM
trottier.ed's Avatar
OK, someone on subject of X-308 cabin pollen/air filter posted link to
Your search - jaguar Tech Service Bulletin TSB 412-09 - did not match any image results.
But, I got "did not match any image results." as noted above.
Somewhere on the "net," I watched a You-tube video of an (04) Red XJR owner replace his Cabin Filter in about 5 mins (it was under glove box, (RH side), pulled down a soft panel, removed 2 plastic fasteners, and there it was). Now "consensus" seems to be that Cabin Filter(s) in X-308 ('97-03) is a "special (rare) order" item. That would explain why I get varied shapes/numbers Part# for "Jaguar XJR 2003 Cabin Air Filter. One post (above) gave Jag's TSB number to explain this, but...well, you can see search result.
Anyone have some sort of "definitive" solution to this apparent "mystery?"
THANKS in advance.
'03 XJR ...15B83MF50806
Aiken, SC (2nd of 2 US owners)
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
axr383
Sep 18, 2015 11:19 AM
chatmanx
Sep 11, 2015 07:17 PM
explorer364
Sep 11, 2015 05:44 PM
