Mystery noise
Old Sep 12, 2013 | 08:23 PM
dsnyder586's Avatar
Default Mystery noise
OK guys,
My XK8 is making a noise when I :
Shift into drive or reverse
Take off
it is a tinkling noise (for lack of a better description) kind of a light metal noise- couldn't find anything upon close inspection.
Ideas?
Old Sep 12, 2013 | 08:42 PM
Gus's Avatar
Gus
The XK8 has 4 universal joints 2 in each axle that are overlooked when lubricating the suspension if you are lucky it will be one of them.
Old Sep 12, 2013 | 11:06 PM
dsnyder586's Avatar
Hmm, I'll definitely hit them with my grease gun- it is a much lighter metal sound though- like a heat shield, but I can't find a loose piece..
Old Sep 12, 2013 | 11:31 PM
Roger77's Avatar
it's the change in your pocket that the XK wants you to spend on it..
Old Sep 13, 2013 | 12:21 AM
dsnyder586's Avatar
Roger! Nice to see you posting- I think you may be right....time to spend some cash...
Old Sep 13, 2013 | 05:24 AM
philhef's Avatar
Is it when you take off and just before it shifts to next gear? Mine has a short, hi pitched zipper sound just before shifting into second and sometimes before third. It sometimes sounds like a metal vibration.
Old Sep 13, 2013 | 08:24 AM
Burdedw's Avatar
Could it be one of the VVT's?
I hear a similar noise when I first take off after the car has been sitting overnight, and I think that's what it is.
Dave B.
1998 XK8
Old Sep 13, 2013 | 08:57 AM
The Coupe's Avatar
Phil,
That sounds like you could be a bit low on transmission fluid. I had the same sound as you...I checked the level, was about a quart low and a top-off solved the problem.
Snyder,
Don't know if this is a help to you or not.
Old Sep 13, 2013 | 09:32 AM
dsnyder586's Avatar
It does not sound internal- its a higher pitched rattle, like a cat converter shield except only when there is a shift from p to R or D and then on takeoff. It *sounds* like it is coming from the rear.
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
