Need help identifying this 98 XK8 part
Old Dec 29, 2018 | 07:02 PM
RonXK8's Avatar
Default Need help identifying this 98 XK8 part
I was working on my 98 XK8 and accidentally broke this small hose. (See ATTACHED photo)
Can someone identify it ... and let me know its function?
Thanks so much!
Ron
Old Dec 29, 2018 | 08:06 PM
RJ237's Avatar
Welcome to the forum, Ron. That's a vacuum hose that enables the cruise control. If possible get a piece of rubber vacuum hose from your local auto supply to patch it. Please visit the new member area and introduce yourself wen you have time.
Old Dec 29, 2018 | 09:04 PM
RonXK8's Avatar
Thanks so much!
I figured it had to be a vacuum line - just wasn't sure for what.
I'll finish filling out my "about" forms - and definitely introduce myself to all.
Thanks again!
Ron
Old Dec 30, 2018 | 08:16 PM
Ltd's Avatar
Ltd
I just broke mine, 1998, as well. Must be the cold weather. Anyway I just patched it together with a 2” piece of vacuum hose.
Old Dec 30, 2018 | 08:19 PM
Ltd's Avatar
Ltd
If this is your ride, your coolant hoses are in sad shape. The bypass hose is swollen, the upper radiator hose is collapsing.
Just an observation.
Ltd
Old Dec 30, 2018 | 08:23 PM
baxtor's Avatar
The radiator hoses almost appear to be under vacuum. Sucked in look??????
Old Jan 1, 2019 | 12:55 AM
Johnken's Avatar
Ron, FWIW, when this vacuum is compromised this will happen. Start a drive, level road or downhill , engage cruise control. All looks ok until you meet a rise in the road. Cruise control will engage to increase throttle for the uphill. Leak prevents this. Car realizes its attempts are futile, cancels and disables cruise control, displays amber warning message (I forget exact verbiage).
the cruise control refreshes when ignition is cycled off on.
I encountered this when my motor mounts needed replacement. Excessive engine movement jiggled the silencer out of the air filter box and tugged on this hose enough to pull it off.
thought you might be interested.
John
Old Jan 2, 2019 | 11:49 PM
RonXK8's Avatar
Must be the photo - all hoses are virtually brand new. (Less than 3000 miles on them)
Had a recent massive temperature/atmospheric pressure change which sometimes causes the hose to temporarily collapse.
But thanks!
Old Jan 3, 2019 | 06:22 AM
Gus's Avatar
Gus
Also consider replacing the coolant tank cap as it has two functions pressure and vacuum release.
Gus
www.jagrepair.com
Old Jan 8, 2019 | 07:50 PM
RonXK8's Avatar
Default Problem Solved - Thanks to all!
Fixed the hose ... and now know what is is for!
Thanks to all for your help!
Old Jan 8, 2019 | 10:36 PM
Johnken's Avatar
Good job!
Diamondrmp
Dec 24, 2013 03:22 PM
Palmero
XJ40 ( XJ81 )
Jun 2, 2013 11:58 AM
Romeoc1984
Mar 11, 2013 03:44 PM
Jag_man81
Dec 6, 2011 01:41 PM
Straight6DOHC
Feb 7, 2011 06:57 AM
