Newbie question: Source for upper wishbone bushings
Old May 20, 2016 | 10:47 AM
Steve-in-ct's Avatar
Default Newbie question: Source for upper wishbone bushings
Gathering parts for my mechanic to do front suspension work on my new (to me) 2003 XK8 convertible. Found everything I need except for the bushings on the upper wishbone. Maybe they're called something different or I missed them. Can someone please send me a link where to get them from?
Old May 20, 2016 | 11:01 AM
part number is MJA1462AB - check out forum sponsor's SNG Barratt's or JAGBITS
Do you want OE or poly? If you want poly bushings go with Powerflex
recommend requesting free Parts catalog from SNG Barratts
MRomanik's Avatar
Veteran: Air Force
You should be able to get them from SNG Barratt, a forum sponsor. Part # is MJA1462AB.
Old May 20, 2016 | 11:16 AM
Thank you both. Will place an order shortly.
Old May 20, 2016 | 12:41 PM
Ungn's Avatar
If you are cheap like me, Rock auto has them for $20 each or $80/set for stock style rubber/steel.
Old May 20, 2016 | 01:29 PM
Thanks, I'm cheap.
Old May 21, 2016 | 10:56 AM
Pristine97XK8Convertible's Avatar
Default Rock auto
Hi Ungn,
Can you post a link to Rock auto. I'm cheap, cheaper, cheapest ...
Old May 21, 2016 | 04:08 PM
Ungn's Avatar
Originally Posted by Pristine97XK8Convertible
Hi Ungn,
1997 Jag XK8 Suspension
Old May 21, 2016 | 08:52 PM
scardini1's Avatar
I went with a set of OE UROs from Rock. They seem to holding up OK after 15K miles.
oldish git
27
Jul 24, 2020 02:05 PM
BobRoy
49
Sep 18, 2016 10:48 AM
Lawrence
XJ40 ( XJ81 )
Apr 3, 2016 07:20 AM
xjtom
Mar 31, 2016 04:16 PM
Hank03
Mar 30, 2016 04:10 PM
