No stored codes with fault(s)?
Old Sep 7, 2009 | 07:55 PM
Gus's Avatar
Gus
Traction control failure could be caused by many things from dirt on a sensor a bad plug/connector or a failed module. Both my cars had the failure and both were caused by the module. Do a search for ABS on any forum. You will have many caused by dirt, poor connection and bad sensors but most are related to the ABS module. Not saying this is your problem, just saying you need to check it out before the extended warranty is up.
go to this link: http://forums.jag-lovers.org/av.php?1216605k87
Old Sep 8, 2009 | 05:48 AM
test point's Avatar
Excellent link there Gus!
The second issue mentioned seems to be the steering column reach/tilt motors. Another common problem that should be fixed under your warranty. Like the ABS module, it is repairable by a hobby mechanic I would certainly demand that the dealer handle it.
Old Sep 8, 2009 | 02:39 PM
test point's Avatar
. . . Am I crazy?
Well . . . you do own a Jaguar.
Dealers are famous for changing out things even without codes.
Being a 9 year old car your warranty probably isn't a Jaguar Select Edition warranty. It must have some requirements/limitations that make the service department question whether they are going to get paid.
Old Sep 8, 2009 | 03:43 PM
Gus's Avatar
Gus
Go for it Tom!
Originally Posted by test point
. . . Am I crazy?
Old Sep 9, 2009 | 08:35 PM
Gus's Avatar
Gus
Did you get a location on the chaffing? It sounds like your car is in good condition for them not to find something expensive.
Gus
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
tonyforman
Sep 10, 2015 07:23 PM
TexasCat
Sep 8, 2015 04:36 AM
