oil on airfilter
Old Jul 21, 2010 | 07:20 AM
neemo's Avatar
Default oil on airfilter
Hi
i have a 1996 XK8
i was changing out my airfilter and noticed that i have oil on it and in the airbox
its coming from the small pipe that connects into the main airbox pipe
can anyone help please
cheers
Old Jul 21, 2010 | 08:48 AM
Paul Pavlik's Avatar
The Part Load Breather may be clogged (located on the left side valve cover). Or, there may be excessive Blow-By caused by worn rings or Nikasil deterioration. Also, check that there are no breaks or torn areas in the Air Tube that goes from the MAF Sensor to the Throttle Body.
Old Jul 21, 2010 | 11:19 AM
H20boy's Avatar
Good call Paul, most likely the part or full load breathers. Thank goodness for air filters!
If the air pipe is slimy (from oil getting past the filter) remove it, take it to the sink and get some dawn soapy water in it to remove any oil film. Then, clean your throttle body, the less oil down inside that, the better.
Old Jul 21, 2010 | 05:51 PM
neemo's Avatar
cheers gents
ive just found a pdf on how to clean the part load breathers and throttle body here http://www.maxperformancecars.com/dm...Clean_MAFS.pdf
ill give it a go tomorrow to see if it sorts it out!
Old Jul 21, 2010 | 09:54 PM
H20boy's Avatar
Yup, that's the one we have in our pages as well. Very good instructions, follow up if you would, and as always, g'luck!
Old Jul 22, 2010 | 05:15 PM
MrTexasDan's Avatar
Originally Posted by neemo
cheers gents
You found it! You found it!
I knew I lost that thing somewhere.
Old Jul 23, 2010 | 11:41 AM
neemo's Avatar
well sorted it out.
the PDF was easy to follow
and managed to snap the thin plastic return pipe for the coolant Doh!
now the headlining is starting to sag and i have a small leak from the plastic thermostat housing when the engine is under load!
just my luck!
Old Jul 23, 2010 | 12:49 PM
H20boy's Avatar
take your small victories when you can, and enjoy them before moving on to the next issue. Good luck.
Old Jul 23, 2010 | 02:08 PM
neemo's Avatar
will do mate
headlining out tomorrow cant wait not!
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
