P1798 TCM Code
Old Mar 31, 2015 | 05:07 PM
MRomanik's Avatar
Veteran: Air Force
Default P1798 TCM Code
tried out the CReader VIII scanner I purchased. I got a P1798 - CAN INST token message missing. Ignition on but not running.
What does INST mean?
Old Mar 31, 2015 | 06:20 PM
Gus's Avatar
Gus
Use this to look up the code
Link http://www.jagrepair.com/images/Auto...%201997-99.pdf
Old Mar 31, 2015 | 06:25 PM
RJ237's Avatar
That could be an indication that you are connected with the wrong protocol. You may have to force the protocol, see if there are options.
Old Mar 31, 2015 | 07:17 PM
Gus's Avatar
Gus
A CAN token is when the TCU and the ECM are not talking. You had no other codes? Chances are the TCM is in trouble or a bad ground. That is my $.02ȼ
Old Apr 1, 2015 | 03:30 AM
JagV8's Avatar
Clear it. Does it come straight back -> genuine fault, else ignore.
Old Apr 1, 2015 | 10:03 AM
MRomanik's Avatar
Veteran: Air Force
Thanks everyone.
Didn't get any other codes.
Can't choose the protocol, chose the manufacturer.
I'll clear it and see what happens.
Old Apr 1, 2015 | 09:17 PM
motorcarman's Avatar
INST is instrument. The INST PK is the GATEWAY to the CAN BUS.
Look at the electrical guide and you will see the NETWORK page near the end of the guide. The DLC goes to the INST and then on to the modules on the CAN bus all the way to the end which is the ABS.
Both the INST and the ABS have 'terminating' resistors so the network 'INTACT' should have about 60 ohms.
bob gauff
Old Apr 4, 2015 | 09:53 AM
MRomanik's Avatar
Veteran: Air Force
Default Update
I cleared the code and it has not come back. I think it was a low voltage issue.
Still learning to use the CReader VIII.
jaggedy
Nov 20, 2022 12:09 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
XJsc-guy
Sep 25, 2015 11:09 AM
thechaosmachine
Sep 23, 2015 10:03 PM
