Part Number For Xenon Headlights Ballast Needed!
Old Sep 22, 2021 | 06:33 PM
Anglicomarine0326's Avatar
Default Part Number For Xenon Headlights Ballast Needed!
I need the Ballast part number for my 03 XKR With Xenon Headlights. It has the oem Jaguar Xenon lights made by Valeo. Is it the same as 04 & 05 models?
Xenon Headlights
Old Sep 23, 2021 | 11:37 AM
bcprice36's Avatar
Anglicomarine0326:
The Number of the Valeo Ballast is: LAD5G. .....This Ballast is for the Low Beam HID Bulb....and they cost something like $100.00.....a piece! .
The High Beam, which your Photo shows as (ON) is a Halogen Bulb that s set in a Reflector Type Light. That High Beam Bulb can be replaced with a short LED Bulb, The Light source on the LED should be the same distance from the Base of the Bulb as the Halogen Bulbs Light source. If you don't have the same distance here, the High Beam will scatter Sparks of Light all around the Beam Pattern. Check out "The Retrofit Store". They have a short Movie about this....
Be sure that you buy the replacement Bulbs of the HID's that have 6000 Color.....That is the Bright White Light you can get....the Wattage should be the highest you can find.
Billy Clyde @ Cinco Ranch
Old Sep 23, 2021 | 11:41 AM
xalty's Avatar
off brand ballasts are like 20 bucks
Old Sep 23, 2021 | 11:47 AM
Originally Posted by bcprice36
Anglicomarine0326:
Amazon has them for 50 dollars! Thanks!
Old Sep 23, 2021 | 01:12 PM
giandanielxk8's Avatar
With the off-brand ballasts, you lose the auto-aim function. Ask me how I know.
Old Sep 23, 2021 | 04:33 PM
Are you saying that unless I buy Valeo brand, the direct fit other brands won't work? Makes no sense.
Old Sep 23, 2021 | 04:35 PM
xalty's Avatar
internally it’s a 4 pin ballast (lad5gl). the other 8 pins functions are self leveling related and they are removed to make them cheaper. you can read the review from someone with a cayenne who lost their self level. if you really want self leveling you can buy old stock
https://www.ebay.com/itm/352520195574
Old Sep 23, 2021 | 09:36 PM
bcprice36's Avatar
Anglicomarine0326,
Uh! YES.....I believe that is what he is saying!
Paul Calvert
Dec 7, 2018 07:04 PM
Tophee
Mar 2, 2018 11:18 AM
FloridaJag
Aug 30, 2011 01:10 AM
yjmcb
Mar 23, 2010 10:08 PM
lynne8090
Sep 10, 2008 07:32 PM
