Please help identifying an XK8
Old Mar 27, 2013 | 08:46 AM
gavnnik's Avatar
Default Please help identifying an XK8
I live in Dubai and am looking at buying a second hand XK8.
The cars local documentation/registration and invoices from the Jag dealer state it is a 4.0l but it was first registered in 2004.
The manual side of the gear shifter only shows 5 gears not 6.
Entirely unconnected by a friend of mine was sold a brand new by three year old Mercedes by a dealer here so I am concerned this might be a 2002 that was never sold until 2004.
The VIN number is SAJAA41F752A41611
Is this a 4.2 or a 4.0?
Old Mar 27, 2013 | 08:55 AM
steveinfrance's Avatar
Our in house VIN decoder seems bust or can't cope with this VIN
You have a lowercase J but even correcting that different VIN decoders say the VIN is incorrect.
Old Mar 27, 2013 | 08:57 AM
gavnnik's Avatar
Unfortunately - We could not find any information for VIN SAJAA41F752A41611
Old Mar 27, 2013 | 09:03 AM
jimbov8's Avatar
Gavnnik,
Something is not right here. Even though the VIN decoder is only approximate, the result anyway would ring alarm bells with me.
Someone else might be able to give a definitive answer but for what its worth, I would not go near it. If it does turn out to be bogus then the authorities should also be informed.
Enter a 17 digit (VIN) car number
Result is approximate and has not decoded successfullyMARKJaguarMODELXJTYPESedan / LimousinePRODUCTION YEAR2011GEARBOXAutomaticENGINE CAPACITY5000FUEL TYPEGasDOORS4/5POWER385 KM (283 kW)
Old Mar 27, 2013 | 09:26 AM
It's probably nothing more sinister than a typo by the OP.
Old Mar 27, 2013 | 09:36 AM
So it looks like this?
If so that is the 6 speed box so it will be post 2003.
Attached Thumbnails Please help identifying an XK8-2008-jaguar-s-type-4-door-sedan-3-0-gear-shift_100271761_l.jpg
Old Mar 27, 2013 | 10:08 AM
RCSign's Avatar
Your Vin # indicates it's a 2005 4.2 coupe Fourth digit indicates airbags for the world market, Here's a post explaining your vin #
https://www.jaguarforums.com/forum/g...ecoding-49929/
Old Mar 27, 2013 | 10:30 AM
pat77's Avatar
That's what I've got:
VIN:
SAJAA41F752A41611
Vehicle:
XK-SERIES / X100
Model year:
2005
Build date:
23-Apr-2004
Version: SERIES 25 Drive: 2 WHL L/H REAR DRIVE Emission requirements: 96 EEC CAR REQUIREMENTS Transmission: 6 SPD AUTO TRANS ZF 6HP26 Engine: 4.2L DAMB NA V8 GAS AJV8-JAG Body style: 2 DOOR COUPE-4 LITE Air conditioning: ATC AIR CONDITIONER
Old Mar 27, 2013 | 11:22 AM
gavnnik's Avatar
it looks sort of like that but what i think is the sports button (with another next to it) is below the shifter
Old Mar 27, 2013 | 11:27 AM
gavnnik's Avatar
Great thanks all.
It's one owner and a full service history so I'm comfortable with the vehicle.
One great thing here is you have to visit a centre, get a test done and transfer ownership there and then so getting a ringer or something like that is almost impossible.
Old Mar 27, 2013 | 11:35 AM
Gus's Avatar
Gus
Isn’t it because 6th gear is overdrive?
Old Mar 27, 2013 | 02:06 PM
gavnnik's Avatar
that's what confused me - 5 on the shifter is a 6 speed box?
Old Mar 27, 2013 | 02:14 PM
Yes, the numbers on the J Gate side indicate the highest gear that he box will select in each position.
So if you put it to 5 it will shift up to 5 and hold.
If you want it to go to six just select drive.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
tlynch
Dec 31, 2020 01:58 PM
mikiep
Dec 20, 2019 07:37 PM
Johnken
Oct 2, 2015 10:12 AM
